- From: Anders Lundstedt <anders AT anderslundstedt.se>
- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Error in Function command
- Date: Tue, 25 Feb 2014 03:30:05 +0100
On Sat, Feb 22, 2014 at 2:32 PM, Rui Baptista
<rpgcbaptista AT gmail.com>
wrote:
> A quick fix is:
> Definition implication (P Q : Prop) : Prop := P -> Q.
> Function truth' P {measure complexity P} : Prop := match P with
> | atom => True
> | conn P Q => implication (truth' P) (truth' Q)
> end.
Thanks, that worked. Is there any workaround when the recursive call
is in the body of a lambda? (See example in my other reply some
minutes ago.)
- [Coq-Club] Error in Function command, Anders Lundstedt, 02/21/2014
- <Possible follow-up(s)>
- Re: [Coq-Club] Error in Function command, julien . forest, 02/21/2014
- Re: [Coq-Club] Error in Function command, Rui Baptista, 02/22/2014
- Re: [Coq-Club] Error in Function command, Anders Lundstedt, 02/25/2014
- Re: [Coq-Club] Error in Function command, Rui Baptista, 02/25/2014
