- To: coq-club Club <coq-club AT inria.fr>
- Subject: [Coq-Club] Propositional extensionality: the return of the revenge
- Date: Wed, 26 Feb 2014 23:56:49 -0500
Hello there,
As some of you may have been expecting, episode two is out. This time featuring co-inductive types!
CoInductive CoFalse : Prop := CF : CoFalse -> False -> CoFalse.
CoInductive Pandora : Prop := C : CoFalse -> Pandora.
Axiom prop_ext : forall P Q : Prop, (P<->Q) -> P = Q.
Lemma foo : Pandora = CoFalse.
apply prop_ext.
constructor.
intro x; destruct x; assumption.
exact C.
Qed.
CoFixpoint loop : CoFalse :=
match foo in (_ = T) return T with eq_refl => C loop end.
Definition ff : False := match loop with CF _ t => t end.
I am still not sure if this is an implementation bug of the guard for cofixpoints or something more fundamental.
Below is a variation done with Arthur Azevedo de Amorim (requires some of the definitions above):
Inductive omega := Omega : omega -> omega.
Lemma H : omega = CoFalse.
Proof.
apply prop_ext; constructor.
induction 1; assumption.
destruct 1; destruct H0.
Qed.
CoFixpoint loop' : CoFalse :=
match H in _ = T return T with
eq_refl =>
Omega match eq_sym H in _ = T return T with eq_refl => loop' end
end.
Definition ff' : False := match loop' with CF _ t => t end.
We'll work on a fix before the next Coq release.
Maxime.
- [Coq-Club] Propositional extensionality: the return of the revenge, Maxime Dénès, 02/27/2014
- Re: [Coq-Club] Propositional extensionality: the return of the revenge, Jason Gross, 02/27/2014
- Re: [Coq-Club] Propositional extensionality: the return of the revenge, Maxime Dénès, 02/27/2014
- Re: [Coq-Club] Propositional extensionality: the return of the revenge, Cedric Auger, 02/27/2014
- Re: [Coq-Club] Propositional extensionality: the return of the, Enrico Tassi, 02/27/2014
