coq-club - Re: [Coq-Club] Propositional extensionality: the return of the revenge
  • To: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Propositional extensionality: the return of the revenge
  • Date: Thu, 27 Feb 2014 00:12:04 -0500
I thought that your extra CoFalse argument to CF was redundant, so I tried removing it.  Then I got
Error:
Recursive definition of loop is ill-formed.
In environment
loop : CoFalse
Recursive call on a non-recursive argument of constructor
"loop".
Recursive definition is:
"match foo in (_ = T) return T with
 | eq_refl => C loop
 end".
What does this mean?  Does Coq somehow think that "loop" is a constructor?  And why is whether or not "loop" is valid for a recursive call dependent on whether or not there's a dummy CoFalse hypothesis of CF?
-Jason
On Wed, Feb 26, 2014 at 11:56 PM, Maxime Dénès <mail AT maximedenes.fr> wrote:
Hello there,
As some of you may have been expecting, episode two is out. This time featuring co-inductive types!
CoInductive CoFalse : Prop := CF : CoFalse -> False -> CoFalse.
CoInductive Pandora : Prop := C : CoFalse -> Pandora.
Axiom prop_ext : forall P Q : Prop, (P<->Q) -> P = Q.
Lemma foo : Pandora = CoFalse.
apply prop_ext.
constructor.
intro x; destruct x; assumption.
exact C.
Qed.
CoFixpoint loop : CoFalse :=
match foo in (_ = T) return T with eq_refl => C loop end.
Definition ff : False := match loop with CF _ t => t end.
I am still not sure if this is an implementation bug of the guard for cofixpoints or something more fundamental.
Below is a variation done with Arthur Azevedo de Amorim (requires some of the definitions above):
Inductive omega := Omega : omega -> omega.
Lemma H : omega = CoFalse.
Proof.
apply prop_ext; constructor.
  induction 1; assumption.
destruct 1; destruct H0.
Qed.
CoFixpoint loop' : CoFalse :=
  match H in _ = T return T with
    eq_refl =>
    Omega match eq_sym H in _ = T return T with eq_refl => loop' end
  end.
Definition ff' : False := match loop' with CF _ t => t end.
We'll work on a fix before the next Coq release.
Maxime.
