- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Propositional extensionality: the return of the revenge
- Date: Thu, 27 Feb 2014 00:21:22 -0500
Hi Jason,
That's because Coq is checking if [loop] is a legal recursive argument for a constructor, but in the wrong type, here [CoFalse] instead of [Pandora].
This is the reason why I said I was not sure if it was an implementation bug or something deeper. However, the second variation does not rely on the same behavior, I believe. More precisely, even fixing this bug, Omega would still have a legitimate recursive argument.
Maxime.
On 02/27/2014 12:12 AM, Jason Gross wrote:
I thought that your extra CoFalse argument to CF was redundant, so I tried removing it. Then I got
Error:
Recursive definition of loop is ill-formed.
In environment
loop : CoFalse
Recursive call on a non-recursive argument of constructor
"loop".
Recursive definition is:
"match foo in (_ = T) return T with
| eq_refl => C loop
end".
What does this mean? Does Coq somehow think that "loop" is a constructor? And why is whether or not "loop" is valid for a recursive call dependent on whether or not there's a dummy CoFalse hypothesis of CF?
-Jason
On Wed, Feb 26, 2014 at 11:56 PM, Maxime Dénès <mail AT maximedenes.fr <mailto:mail AT maximedenes.fr>> wrote:
Hello there,
As some of you may have been expecting, episode two is out. This
time featuring co-inductive types!
CoInductive CoFalse : Prop := CF : CoFalse -> False -> CoFalse.
CoInductive Pandora : Prop := C : CoFalse -> Pandora.
Axiom prop_ext : forall P Q : Prop, (P<->Q) -> P = Q.
Lemma foo : Pandora = CoFalse.
apply prop_ext.
constructor.
intro x; destruct x; assumption.
exact C.
Qed.
CoFixpoint loop : CoFalse :=
match foo in (_ = T) return T with eq_refl => C loop end.
Definition ff : False := match loop with CF _ t => t end.
I am still not sure if this is an implementation bug of the guard
for cofixpoints or something more fundamental.
Below is a variation done with Arthur Azevedo de Amorim (requires
some of the definitions above):
Inductive omega := Omega : omega -> omega.
Lemma H : omega = CoFalse.
Proof.
apply prop_ext; constructor.
induction 1; assumption.
destruct 1; destruct H0.
Qed.
CoFixpoint loop' : CoFalse :=
match H in _ = T return T with
eq_refl =>
Omega match eq_sym H in _ = T return T with eq_refl => loop' end
end.
Definition ff' : False := match loop' with CF _ t => t end.
We'll work on a fix before the next Coq release.
Maxime.
- [Coq-Club] Propositional extensionality: the return of the revenge, Maxime Dénès, 02/27/2014
- Re: [Coq-Club] Propositional extensionality: the return of the revenge, Jason Gross, 02/27/2014
- Re: [Coq-Club] Propositional extensionality: the return of the revenge, Maxime Dénès, 02/27/2014
- Re: [Coq-Club] Propositional extensionality: the return of the revenge, Cedric Auger, 02/27/2014
- Re: [Coq-Club] Propositional extensionality: the return of the, Enrico Tassi, 02/27/2014
