- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: [Coq-Club] Rewriting with equivalence relations in Set / Type
- Date: Thu, 27 Feb 2014 15:57:57 +0000
(* I think I'm close to finding a way of rewriting with equivalence relations in Set / Type, except [eauto] isn't cooperating. This technique would allow rewriting under quantifiers. It would allow rewriting under lambdas too if an axiom is used. It would only work for terms in the conclusion of a goal. If the term we would want to rewrite isn't in the conclusion of the goal, we'd have to [revert] it first. If it were possible to tell [eauto] to ignore the first n successes, it would be possible to rewrite at the n-th occurrence. It might be necessary to clear the [core] database to avoid interference. I'm not sure if this method would work for a term with a lot of depedent types. *)
Definition iff : Type -> Type -> Type := fun t1 t2 => ((t1 -> t2) * (t2 -> t1))%type.
Definition not : Type -> Type := fun t1 => t1 -> False.
Axiom equivalent : nat -> nat -> Set.
Axiom add : nat -> nat -> nat.
Axiom double : nat -> nat.
Infix "<~>" := iff (at level 95).
Notation "~~" := not.
Infix "~" := equivalent (at level 70).
(* We start our rewrites with this. *)
Axiom iff_forwards : forall t1 t2, (t1 <~> t2) -> t2 -> t1.
Axiom iff_backwards : forall t1 t2, (t1 <~> t2) -> t1 -> t2.
(* This would be our database of compatability theorems. *)
Axiom A1 : forall t1 t2, (t1 <~> t2) -> (~~ t1 <~> ~~ t2).
Axiom A2 : forall t1 t2 t3, (t1 <~> t2) -> ((t1 -> t3) <~> (t2 -> t3)).
Axiom A3 : forall t1 t2 t3, (t1 <~> t2) -> ((t3 -> t1) <~> (t3 -> t2)).
Axiom A4 : forall t1 t2 t3, (t1 <~> t2) -> (t1 + t3 <~> t2 + t3).
Axiom A5 : forall t1 t2 t3, (t1 <~> t2) -> (t3 + t1 <~> t3 + t2).
Axiom A6 : forall t1 t2 t3, (t1 <~> t2) -> (t1 * t3 <~> t2 * t3).
Axiom A7 : forall t1 t2 t3, (t1 <~> t2) -> (t3 * t1 <~> t3 * t2).
Axiom A8 : forall t1 p1 p2, (forall x1, p1 x1 <~> p2 x1) -> ((forall x1 : t1, p1 x1) <~> (forall x1 : t1, p2 x1)).
Axiom A9 : forall t1 p1 p2, (forall x1, p1 x1 <~> p2 x1) -> ({x1 : t1 & p1 x1} <~> {x1 : t1 & p2 x1}).
Axiom A10 : forall n1 n2 n3, n1 ~ n2 -> (n1 ~ n3 <~> n2 ~ n3).
Axiom A11 : forall n1 n2 n3, n1 ~ n2 -> (n3 ~ n1 <~> n3 ~ n2).
Hint Resolve A1 A2 A3 A4 A5 A6 A7 A8 A9 A10 A11 : CompatHints.
(* These are the tactics for rewriting forwards and backwards. *)
Ltac rw_f h1 := refine (iff_forwards _ _ _ _); [solve [eauto 128 using h1 with CompatHints] | lazy beta].
Ltac rw_b h1 := refine (iff_backwards _ _ _ _); [solve [eauto 128 using h1 with CompatHints] | lazy beta].
(* We want to rewrite with this *)
Axiom A12 : forall n1, double n1 ~ add n1 n1.
(* in this. *)
Goal ~~ ((False -> (False + ((False * (forall x1, {x2 : nat & double x1 ~ x2})) * False)) + False) -> False).
(* This works. *)
refine (iff_forwards _ _ _ _).
eapply A1.
eapply A2.
eapply A3.
eapply A4.
eapply A5.
eapply A6.
eapply A7.
eapply A8.
intro.
eapply A9.
intro.
eapply A10.
eapply A12.
lazy beta.
(* This is supposed to be equivalent, but doesn't work. *)
refine (iff_backwards _ _ _ _).
eauto 128 using A12 with CompatHints.
lazy beta.
(* This too. *)
rw_f A12.
(* It would be possible to build autorewrite databases using the trick that has been posted previously in this mailing list. *)
Tactic Notation "autorw" := rw h1.
Tactic Notation "autorw" := autorw || rw h2.
Tactic Notation "autorw" := autorw || rw h3.
- [Coq-Club] Rewriting with equivalence relations in Set / Type, Rui Baptista, 02/27/2014
- <Possible follow-up(s)>
- Re: [Coq-Club] Rewriting with equivalence relations in Set / Type, Jason Gross, 02/27/2014
- Re: [Coq-Club] Rewriting with equivalence relations in Set / Type, Rui Baptista, 02/27/2014
- Re: [Coq-Club] Rewriting with equivalence relations in Set / Type, Pierre-Marie Pédrot, 02/28/2014
- Re: [Coq-Club] Rewriting with equivalence relations in Set / Type, Rui Baptista, 02/28/2014
- Re: [Coq-Club] Rewriting with equivalence relations in Set / Type, Robbert Krebbers, 02/28/2014
