coq-club - Re: [Coq-Club] Rewriting with equivalence relations in Set / Type
  • To: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Rewriting with equivalence relations in Set / Type
  • Date: Thu, 27 Feb 2014 17:53:06 -0500
Isn't there a command for deleting theorems from the databases auto uses? I think I remember reading about that in this mailing list.
I believe it was requested and might be planed, but not yet implemented.
-Jason
On Thu, Feb 27, 2014 at 5:42 PM, Rui Baptista <rpgcbaptista AT gmail.com> wrote:
I haven't tried reverse engineering rewriting with type classes yet.
I think it's possible to get a little bit better performance. Now it's not necessary to make [not] opaque.
Hint Extern 1 (_ <~> _) => simple apply A1 : CompatHints.
Hint Extern 1 (_ <~> _) => simple apply A2 : CompatHints.
Hint Extern 1 (_ <~> _) => simple apply A3 : CompatHints.
Hint Extern 1 (_ <~> _) => simple apply A4 : CompatHints.
Hint Extern 1 (_ <~> _) => simple apply A5 : CompatHints.
Hint Extern 1 (_ <~> _) => simple apply A6 : CompatHints.
Hint Extern 1 (_ <~> _) => simple apply A7 : CompatHints.
Hint Extern 1 (_ <~> _) => apply A8 : CompatHints.
Hint Extern 1 (_ <~> _) => apply A9 : CompatHints.
Hint Extern 1 (_ <~> _) => simple apply A10 : CompatHints.
Hint Extern 1 (_ <~> _) => simple apply A11 : CompatHints.
Ltac rw_f h1 := refine (iff_forwards _ _ _ _); [solve [auto 128 using h1 with CompatHints] | lazy beta].
Ltac rw_b h1 := refine (iff_backwards _ _ _ _); [solve [auto 128 using h1 with CompatHints] | lazy beta].
Axiom A12 : forall n1, double n1 ~ add n1 n1.
Goal ~~ ((False -> ((False + ((False * (forall x1, {x2 : nat & double x1 ~ x2})) * False)) + False)) -> False).
rw_f A12.
rw_b A12.
On Thu, Feb 27, 2014 at 9:28 PM, Jason Gross <jasongross9 AT gmail.com> wrote:
I believe Matthieu Sozeau is working on getting the setoid_rewrite machinery to handle relations in Type, and also (I think?) dependent/heterogeneous relations.  It will hopefully be in Coq 8.5.  Have you looked at how setoid_rewriting is implemented with typeclass resolution?
-Jason
On Thu, Feb 27, 2014 at 4:21 PM, Rui Baptista <rpgcbaptista AT gmail.com> wrote:
It works if I use
Hint Extern 1 => apply A1 : CompatHints.
Hint Extern 1 => apply A2 : CompatHints.
Hint Extern 1 => apply A3 : CompatHints.
Hint Extern 1 => apply A4 : CompatHints.
Hint Extern 1 => apply A5 : CompatHints.
Hint Extern 1 => apply A6 : CompatHints.
Hint Extern 1 => apply A7 : CompatHints.
Hint Extern 1 => apply A8 : CompatHints.
Hint Extern 1 => apply A9 : CompatHints.
Hint Extern 1 => apply A10 : CompatHints.
Hint Extern 1 => apply A11 : CompatHints.
instead of
Hint Resolve A1 A2 A3 A4 A5 A6 A7 A8 A9 A10 A11 : CompatHints.
But it's kind of slow, and I'm forced to use
Global Opaque not.
so it doesn't unfold not. Also, it prefers to use compatibility with universal quantification instead of implication.
I used refine (iff_backwards _ _ _ _) when I should have used refine (iff_forwards _ _ _ _).
