coq-club - Re: [Coq-Club] Rewriting with equivalence relations in Set / Type
  • To: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Rewriting with equivalence relations in Set / Type
  • Date: Thu, 27 Feb 2014 16:28:34 -0500
I believe Matthieu Sozeau is working on getting the setoid_rewrite machinery to handle relations in Type, and also (I think?) dependent/heterogeneous relations.  It will hopefully be in Coq 8.5.  Have you looked at how setoid_rewriting is implemented with typeclass resolution?
-Jason
On Thu, Feb 27, 2014 at 4:21 PM, Rui Baptista <rpgcbaptista AT gmail.com> wrote:
It works if I use
Hint Extern 1 => apply A1 : CompatHints.
Hint Extern 1 => apply A2 : CompatHints.
Hint Extern 1 => apply A3 : CompatHints.
Hint Extern 1 => apply A4 : CompatHints.
Hint Extern 1 => apply A5 : CompatHints.
Hint Extern 1 => apply A6 : CompatHints.
Hint Extern 1 => apply A7 : CompatHints.
Hint Extern 1 => apply A8 : CompatHints.
Hint Extern 1 => apply A9 : CompatHints.
Hint Extern 1 => apply A10 : CompatHints.
Hint Extern 1 => apply A11 : CompatHints.
instead of
Hint Resolve A1 A2 A3 A4 A5 A6 A7 A8 A9 A10 A11 : CompatHints.
But it's kind of slow, and I'm forced to use
Global Opaque not.
so it doesn't unfold not. Also, it prefers to use compatibility with universal quantification instead of implication.
I used refine (iff_backwards _ _ _ _) when I should have used refine (iff_forwards _ _ _ _).
