- To: coq club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] how to write this function?
- Date: Sat, 5 Apr 2014 21:35:40 +0300
2014-04-05 21:31 GMT+03:00 Robbert Krebbers
<mailinglists AT robbertkrebbers.nl>:
> That is because you are using natural numbers in unary representation.
> Already something like:
> Check 362880.
> results in
> Warning: Stack overflow or segmentation fault happens
> when working with large numbers in nat (observed
> threshold may vary from 5000 to 70000 depending on
> your system limits and on the command executed).
> Stack overflow.
> Better use a more efficient representation for natural numbers like N (an
> inductive representation as bit sequences) or bigN (arbitrary precision
> machine integers).
Ah, that makes sense, thanks Robbert!
Any ideas about rest of my questions?
Ömer Sinan Ağacan
http://osa1.net
- [Coq-Club] how to write this function?, Ömer Sinan Ağacan, 04/05/2014
- Re: [Coq-Club] how to write this function?, Robbert Krebbers, 04/05/2014
- Re: [Coq-Club] how to write this function?, Ömer Sinan Ağacan, 04/05/2014
- Re: [Coq-Club] how to write this function?, Daniel Schepler, 04/05/2014
- Re: [Coq-Club] how to write this function?, Adam Chlipala, 04/05/2014
