- To: Ömer Sinan Ağacan <omeragacan AT gmail.com>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] how to write this function?
- Date: Sat, 05 Apr 2014 15:38:06 -0400
It sounds to me like you're getting into territory where ad-hoc answers on a mailing list won't be very effective. An introduction to programming with dependent types in Coq (e.g., CPDT <http://adam.chlipala.net/cpdt/>) is probably worth reading.
On 04/05/2014 03:34 PM, Ömer Sinan Ağacan wrote:
Thanks for your answer! I tried using eq_nat_dec without using lemmas,
just to see how error will change and how does that help Coq inferring
stop = n, but it's still giving same error message:
Fixpoint nth_triangle_aux {T : Type} (idx stop : nat) (tr :
triangle_t T idx) : Vector.t T stop :=
if eq_nat_dec idx stop then
match tr with triangle _ _ v _ => v end
else
match tr with triangle _ _ _ tr' => nth_triangle_aux (S idx) stop tr'
end.
Error:
In environment
nth_triangle_aux : forall (T : Type) (idx stop : nat),
triangle_t T idx -> Vector.t T stop
T : Type
idx : nat
stop : nat
tr : triangle_t T idx
e : idx = stop
T0 : Type
n : nat
v : Vector.t T0 n
t : triangle_t T0 (S n)
The term "v" has type "Vector.t T0 n" while it is expected to have type
"Vector.t ?23 stop".
Is there anything else I need to do for telling Coq that stop = n?
- [Coq-Club] how to write this function?, Ömer Sinan Ağacan, 04/05/2014
- Re: [Coq-Club] how to write this function?, Robbert Krebbers, 04/05/2014
- Re: [Coq-Club] how to write this function?, Ömer Sinan Ağacan, 04/05/2014
- Re: [Coq-Club] how to write this function?, Daniel Schepler, 04/05/2014
- Re: [Coq-Club] how to write this function?, Adam Chlipala, 04/05/2014
