- To: coq-club AT inria.fr
- Cc: Ömer Sinan Ağacan <omeragacan AT gmail.com>
- Subject: Re: [Coq-Club] how to write this function?
- Date: Sat, 05 Apr 2014 12:20:07 -0700
On Saturday, April 05, 2014 09:35:40 PM Ömer Sinan Ağacan wrote:
> 2014-04-05 21:31 GMT+03:00 Robbert Krebbers
<mailinglists AT robbertkrebbers.nl>:
> > That is because you are using natural numbers in unary representation.
> > Already something like:
> > Check 362880.
> > results in
> > Warning: Stack overflow or segmentation fault happens
> > when working with large numbers in nat (observed
> > threshold may vary from 5000 to 70000 depending on
> > your system limits and on the command executed).
> > Stack overflow.
> > Better use a more efficient representation for natural numbers like N (an
> > inductive representation as bit sequences) or bigN (arbitrary precision
> > machine integers).
> Ah, that makes sense, thanks Robbert!
> Any ideas about rest of my questions?
If you use the Program facility, and use eq_nat_dec instead of beq_nat to get
some proof content out of the result, then that takes care of the immediate
issue. But then you run into the issue that Coq can't detect a decreasing
argument of the fixpoint (and indeed, if idx > stop then the fixpoint won't
terminate). So my solution is to add an argument whose type is an inductive
Prop, constructed specifically so that it "decreases" on each step:
Require Import Program.
Inductive alt_ge (n : nat) : nat -> Prop :=
| alt_ge_n : alt_ge n n
| alt_ge_step : forall m:nat, alt_ge n (S m) -> alt_ge n m.
Lemma alt_ge_conv : forall {n m:nat}, alt_ge n m -> n <> m ->
alt_ge n (S m).
Proof.
destruct 1; trivial.
intro H; contradiction H; trivial.
Defined.
(* or:
Definition alt_ge_conv {n m:nat} (Hge : alt_ge n m) :
n <> m -> alt_ge n (S m) :=
match Hge in (alt_ge _ m) return (n <> m -> alt_ge n (S m)) with
| alt_ge_n => fun Hneq : n <> n => False_ind _ (Hneq eq_refl)
| alt_ge_step m H => fun _ => H
end.
which is why alt_ge_conv Hge is considered "smaller" than Hge
Program Fixpoint nth_triangle_aux {T : Type} (idx stop : nat)
(tr : triangle_t T idx) (Hge : alt_ge stop idx) {struct Hge} :
Vector.t T stop :=
if eq_nat_dec idx stop then
match tr with triangle _ _ v _ => v end
else
match tr with triangle _ _ _ tr' =>
nth_triangle_aux (S idx) stop tr' (alt_ge_conv _ _)
end.
Lemma alt_ge_trans : forall n m p:nat, alt_ge n m -> alt_ge m p ->
alt_ge n p.
Proof.
induction 2; auto using alt_ge.
Defined.
Lemma alt_ge_n_O : forall n:nat, alt_ge n 0.
Proof.
induction n; eauto using alt_ge_trans, alt_ge.
Defined.
Definition nth_triangle {T : Type} (idx : nat)
(tr : triangle_t T 0) : Vector.t T idx :=
nth_triangle_aux 0 idx tr (alt_ge_n_O _).
Recursive Extraction nth_triangle.
Daniel Schepler
- [Coq-Club] how to write this function?, Ömer Sinan Ağacan, 04/05/2014
- Re: [Coq-Club] how to write this function?, Robbert Krebbers, 04/05/2014
- Re: [Coq-Club] how to write this function?, Ömer Sinan Ağacan, 04/05/2014
- Re: [Coq-Club] how to write this function?, Daniel Schepler, 04/05/2014
- Re: [Coq-Club] how to write this function?, Adam Chlipala, 04/05/2014
