Re: [Coq-Club] Pattern matching on vectors: How to tell Coq that tail is one shorter than the discriminee?
- From: Arthur Azevedo de Amorim <arthur.aa AT gmail.com>
- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Pattern matching on vectors: How to tell Coq that tail is one shorter than the discriminee?
- Date: Mon, 14 Apr 2014 00:39:58 +0200
2014-04-13 5:21 GMT+02:00 Ömer Sinan Ağacan
<omeragacan AT gmail.com>:
> Thanks for your answer, it worked! I don't understand how can this
> code work, though. Because pattern matching has different return type
> than the function.
They do look different superficially, but they are actually the same.
Remember that len' is actually S len. Thus, if you substitute S len
for len' in the return type of the match, you get
match S len with
| 0 => unit
| S len => Vector.t nat (S len)
end
which reduces to
allowing Coq to type-check the definition.
In a nutshell, this confusing return type arises because when Coq
type-checks a match, it requires you to generalize over the indices of
your scrutinee (in this case, the length of the vector). This is what
the "as" part of the declaration means. When this happens, Coq
"forgets" that len' is actually S len, and you need to write something
that makes sense for any possible natural number, not just S len. This
is the reason why we need the "0 => unit" branch on the return clause.
Only after accepting the match will Coq use the actual length of your
vector (in this case, S len) to type-check the rest of the definition.
Then, it performs the above substitution and realizes everything is
OK.
> Also, I tried replacing `v'` with `_` and using `refine` tactic, but I
> didn't get `Vector h' 0 someFreshVar = v'` as hypothesis while filling
> the case with `as v'`. Why I never get this types of equalities in
> pattern matching?
> Thanks again.
> Ömer Sinan Ağacan
> http://osa1.net
- [Coq-Club] Pattern matching on vectors: How to tell Coq that tail is one shorter than the discriminee?, Ömer Sinan Ağacan, 04/12/2014
- Re: [Coq-Club] Pattern matching on vectors: How to tell Coq that tail is one shorter than the discriminee?, Arthur Azevedo de Amorim, 04/12/2014
- Re: [Coq-Club] Pattern matching on vectors: How to tell Coq that tail is one shorter than the discriminee?, Ömer Sinan Ağacan, 04/13/2014
- Re: [Coq-Club] Pattern matching on vectors: How to tell Coq that tail is one shorter than the discriminee?, Abhishek Anand, 04/13/2014
- Re: [Coq-Club] Pattern matching on vectors: How to tell Coq that tail is one shorter than the discriminee?, AUGER Cédric, 04/13/2014
- Re: [Coq-Club] Pattern matching on vectors: How to tell Coq that tail is one shorter than the discriminee?, Arthur Azevedo de Amorim, 04/14/2014
