- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] external proof of termination
- Date: Fri, 25 Apr 2014 12:03:06 -0400
I would expect such a proof to be metatheoretic, because Coq is believed to be consistent with the axiom [exists x, P x -> { x | P x }].
If you can refine your termination lemma to live in Set rather than Prop, you should be fine; can you prove forall x, { n : nat | exists y, f x n = Some y }?
-Jason
On Apr 25, 2014 11:52 AM, "Adam Chlipala" <adamc AT csail.mit.edu> wrote:
It wouldn't surprise me if one can prove that there is no such way. The [n] argument to [f] lives in [Set], while your [termination] proof lives in [Prop], and information is not supposed to be able to flow out of proofs into regular program execution! Clearly the [n] argument has computational significance here; it isn't just an artifact of termination proof like in Coq's well-founded recursion.
On 04/25/2014 11:49 AM, Kirill Taran wrote:
Hello,
I have a fixpoint with "fuel" argument (i.e. argument which restricts depth of recursion).
Then I have a proof that for any argument of this fixpoint there is such "fuel" value, that
the fixpoint suceeds.
Fixpoint f (x : X) (n : nat) : option Y := ...
Lemma termination : forall x, exists n y, f x n = Some y.
But then I somehow can't invent a way to compose then into "good" fixpoint:
Fixpoint f' (x : X) : Y.
Could anybody prompt me how to incorporate the proof into "good" fixpoint?
Sincerely,
Kirill Taran
- [Coq-Club] external proof of termination, Kirill Taran, 04/25/2014
- Re: [Coq-Club] external proof of termination, Adam Chlipala, 04/25/2014
- Re: [Coq-Club] external proof of termination, Jason Gross, 04/25/2014
- Re: [Coq-Club] external proof of termination, Arnaud Spiwack, 04/28/2014
- Re: [Coq-Club] external proof of termination, Eddy Westbrook, 04/28/2014
- Re: [Coq-Club] external proof of termination, Arnaud Spiwack, 04/30/2014
- Re: [Coq-Club] external proof of termination, Eddy Westbrook, 04/25/2014
- Re: [Coq-Club] external proof of termination, Kirill Taran, 04/25/2014
- Re: [Coq-Club] external proof of termination, gallais, 04/28/2014
