- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] external proof of termination
- Date: Fri, 25 Apr 2014 09:21:06 -0700
Kirill,
If you use { n | exists y, f x n = Some y }, you can get y out by calling f! Specifically, you should be able to make a Definition of type X -> Y, that first calls “termination” to get the n, then calls f with its arguments, and then proves that f returns a "Some y”.
Also, if you want to build a dependent pair type where the right-hand side is in Set, use “&” instead of “|”, like this: { n : nat & { y | … } }
-E
On Apr 25, 2014, at 9:16 AM, Kirill Taran <kirill.t256 AT gmail.com> wrote:
Actually, I just didn't notice this issue with universes difference.
Suppose, that I can prove termination in Set.
> (Jason) If you can refine your termination lemma to live in Set rather than Prop, you should be fine
> (Eddy) then you could use this function to generate the n argument to f
It is clear, seems that I didn't succeed earlier because just couldn't destruct "exists"
(I tried to defined "good" fixpoint with tactics and Coq gave me error about "exists":
"Case analysis on sort Set is not allowed for inductive definition ex").
Also, I am not sure that { n | exists y, f x n = Some y } is ok for me,
because I need to extract y, but it is inside Prop again.
And I can't construct { n | { y | f x n = Some y } },
because second argument must be in Prop.
Sincerely,
Kirill TaranOn Fri, Apr 25, 2014 at 8:03 PM, Eddy Westbrook <westbrook AT kestrel.edu> wrote:Kirill,Expanding on Adam’s response, if you could prove termination as something like this:Lemma termination : forall x, { n | exists y, f x n = Some y }then you could use this function to generate the n argument to f. This is because the { n | … } construct is in Set, while exists n, … is in Prop.If you cannot prove termination in Set but you really need to call f with it, then there are a number of axioms you could use, such as indefinite description (in the library Coq.Logic.IndefiniteDescription), but, because these are axioms, they will get “stuck” and not ever actually produce your “fuel”.-EOn Apr 25, 2014, at 8:51 AM, Adam Chlipala <adamc AT csail.mit.edu> wrote:It wouldn't surprise me if one can prove that there is no such way. The [n] argument to [f] lives in [Set], while your [termination] proof lives in [Prop], and information is not supposed to be able to flow out of proofs into regular program execution! Clearly the [n] argument has computational significance here; it isn't just an artifact of termination proof like in Coq's well-founded recursion.
On 04/25/2014 11:49 AM, Kirill Taran wrote:
Hello,
I have a fixpoint with "fuel" argument (i.e. argument which restricts depth of recursion).
Then I have a proof that for any argument of this fixpoint there is such "fuel" value, that
the fixpoint suceeds.
Fixpoint f (x : X) (n : nat) : option Y := ...
Lemma termination : forall x, exists n y, f x n = Some y.
But then I somehow can't invent a way to compose then into "good" fixpoint:
Fixpoint f' (x : X) : Y.
Could anybody prompt me how to incorporate the proof into "good" fixpoint?
Sincerely,
Kirill Taran
- [Coq-Club] external proof of termination, Kirill Taran, 04/25/2014
- Re: [Coq-Club] external proof of termination, Adam Chlipala, 04/25/2014
- Re: [Coq-Club] external proof of termination, Jason Gross, 04/25/2014
- Re: [Coq-Club] external proof of termination, Arnaud Spiwack, 04/28/2014
- Re: [Coq-Club] external proof of termination, Eddy Westbrook, 04/25/2014
- Re: [Coq-Club] external proof of termination, Kirill Taran, 04/25/2014
- Re: [Coq-Club] external proof of termination, gallais, 04/28/2014
- Re: [Coq-Club] external proof of termination, Guillaume Melquiond, 04/25/2014
- Re: [Coq-Club] external proof of termination, Kirill Taran, 04/26/2014
