coq-club - Re: [Coq-Club] Erasable Red/Black Trees in Coq
  • To: coq-club AT inria.fr
  • Cc: jonikelee AT gmail.com
  • Subject: Re: [Coq-Club] Erasable Red/Black Trees in Coq
  • Date: Sat, 26 Apr 2014 11:17:12 +0200
Le Fri, 25 Apr 2014 23:24:02 -0400,
Jonathan
<jonikelee AT gmail.com>
a écrit :
> Arnaud,
> I somewhat expected to get associative rewriting of ILists as well -
> but that isn't working:
> Remark assoc_rw : forall A (p q r s:IList A), q++r = s ->
> (p++q)++r = p++s.
> Proof.
> intros A p q r s H.
> rewrite H.(*fails*)
> I guess the thing to do is to use the AACTactics library with ILists.
> -- Jonathan
If that really is your code, it seems normal, as "rewrite H." where
H:q++r=s replace all occurences of q++r with s, and there is no
occurence of q++r.
If you want to rewrite the otherway (ie. s into q++r), you can try:
* subst H. (* This tactic rewrite equalities of the form var=exp or
exp=var in the right direction *)
* destruct H. (* see the documentation, and see also "case H." *)
* rewrite <- H.
There is also a pattern I use a lot, but that I do not advise to use as
it looks completely cryptic:
"intros A p q r _ []."
It is equivalent to "intros A p q r s H; case H as []; clear s."
Furthermore, why not simply prove that:
Remark assoc_rw : forall A (p q r:IList A),
(p++q)++r = p++(q++r).
