coq-club - Re: [Coq-Club] Erasable Red/Black Trees in Coq
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Erasable Red/Black Trees in Coq
  • Date: Thu, 24 Apr 2014 10:45:13 -0400
On 04/23/2014 01:46 PM, Arnaud Spiwack wrote:
Well, indefinite description is incompatible with the impredicativity of
Prop anyway. Definite description is compatible with Coq, but is indeed
incompatible with erasure.
Interestingly, the IList code appears to work without the -impredicative-set flag. Are you sure it needs it?
I have indeed implemented a set of proper backtracking primitive in trunk.
The main one is called "+" (use as t1+t2) and properly backtracks on
subsequent failure. Now, I don't know what exactly you are after, hence I
can't give you more precise advice.
I was primarily using eauto, so I will have to create my own try-different-things tactics that use +. I have yet to try that, so I don't know what will be needed in addition to +.
-- Jonathan
