- From: Arnaud Spiwack <aspiwack AT lix.polytechnique.fr>
- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Erasable Red/Black Trees in Coq
- Date: Thu, 24 Apr 2014 23:39:36 +0200
Is it strange at all then that I can get IList.v through the type checker without using -impredicative-set, including the recursor and induction?
Are you using Proof General to run the file ? If so, the first line of the file:
(* -*- coq-prog-args: ("-emacs-U" "-impredicative-set") -*- *)
automatically passes the -impredicative-set flag to Coq.
PS: I juste noticed that this conversation has been going partially in private and partially on the public list. For the benefit of all, let me attach my file to this mail.
(* -*- coq-prog-args: ("-emacs-U" "-impredicative-set") -*- *) Require Coq.Lists.List. Definition IList (A:Set) : Set := forall R:Set, (A->R->R) -> R -> R . Definition empty {A:Set} : IList A := fun R c e => e . Arguments empty {A} R c e /. Definition single {A:Set} (x:A) : IList A := fun R c e => c x e . Arguments single {A} x R c e /. Definition app {A:Set} (l r:IList A) : IList A := fun R c e => l R c (r R c e) . Arguments app {A} l r R c e /. Notation "l ++ r" := (app l r). Definition cons {A:Set} (x:A) (l:IList A) : IList A := (single x)++l. Arguments cons {A} x l R c e /. Remark app_empty_neutral_r : forall A (l:IList A), l++empty = l. Proof. intros **. reflexivity. Qed. Remark app_empty_neutral_l : forall A (l:IList A), empty++l = l. Proof. intros **. reflexivity. Qed. Remark app_associative : forall A (l r q:IList A), (l++r)++q = l++(r++q). Proof. intros **. reflexivity. Qed. Definition fold_right {A B:Set} (f:A->B->B) (s:B) (l:IList A) : B := l B f s. Definition ilist_rec0 {A B:Set} (s:B) (f:A->IList A->B->B) (l:IList A) : B := snd (fold_right (fun a lb => (cons a (fst lb) , f a (fst lb) (snd lb))) (empty,s) l) . (** Parametricity and is needed to show that impredicative lists are equivalent to lists *) Notation "A ⇔ B" := (A->B->Prop) (at level 70). Definition arrow_rel {A A' B B':Type} (rA:A⇔A') (rB:B⇔B') : (A->B)⇔(A'->B') := fun f g => forall x y, rA x y -> rB (f x) (g y) . Arguments arrow_rel {A A' B B'} rA rB f g /. Notation "rA ⟶ rB" := (arrow_rel rA rB) (at level 70, right associativity). Definition forall_rel {B₁:Set->Set} {B₂:Set->Set} (rB:forall (A₁ A₂:Set) (r:A₁⇔A₂), B₁ A₁⇔B₂ A₂) : (forall x, B₁ x) ⇔ (forall x, B₂ x) := fun f g => forall (A₁ A₂:Set) (rA:A₁⇔A₂), rB A₁ A₂ rA (f A₁) (g A₂) . Notation "∀ ( r : A₁ ⇔ A₂ ) , rB" := (forall_rel (fun A₁ A₂ r => rB)) (at level 90, r ident, A₁ ident, A₂ ident). Definition Parametric {A:Set} (rA:A⇔A) (l:IList A) : Prop := (∀ (r:R⇔R'), (rA ⟶ r ⟶ r) ⟶ r ⟶ r) l l . Definition list_to_ilist {A:Set} (l:list A) : IList A := List.fold_right cons empty l . Definition ilist_to_list {A:Set} (l:IList A) : list A := fold_right (@List.cons _) List.nil l . Lemma list_retract : forall (A:Set) (l:list A), ilist_to_list (list_to_ilist l) = l. Proof. intros A l. induction l as [|x l h]. + easy. + simpl. unfold cons,single,app,ilist_to_list,fold_right in *. congruence. Qed. (* Basic usage of parametricity, as an example *) Remark ilist_param_cons_empty_id : forall (A:Set) (l:IList A), Parametric (@eq A) l -> forall R c e, l _ cons empty R c e = l R c e. Proof. intros * param *. specialize (param (IList A) R (fun l z => l R c e = z)). simpl in param. apply param. + intros x y <- l' z' h. simpl. congruence. + easy. Qed. Lemma ilist_param_retract : forall (A:Set) (l:IList A), Parametric (@eq A) l -> forall R c e, list_to_ilist (ilist_to_list l) R c e = l R c e. Proof. intros * param *. unfold ilist_to_list,fold_right. specialize (param (list A) R (fun l z => list_to_ilist l R c e = z)). simpl in param. apply param. + intros x y <- l' z' h. simpl. congruence. + easy. Qed. (** Induction is harder than recursion because it is not true without parametricity or functional extensionality. Apart from that, it is basically the same definition as [ilist_rec0], but with [{l:IList A|P x}] instead of [(IList A*B)]. *) Theorem ilist_param_ind (A:Set) (P:IList A->Prop) (s:P empty) (f:forall (x:A) (l:IList A), P l -> P (cons x l)) (l:IList A) : Parametric (@eq A) l -> (forall l', (forall R c e, l' R c e = l R c e) -> l'=l) -> P l. Proof. intros param ext. set (ind:= fold_right (fun a lp => exist P (cons a (proj1_sig lp)) (f a (proj1_sig lp) (proj2_sig lp))) (exist P empty s) l). assert (proj1_sig ind = l) as h. { apply ext. intros R c e. unfold ind, fold_right. specialize (param {x|P x} R (fun lp z => proj1_sig lp R c e = z)). simpl in param. apply param. + intros x y <- lp z h. simpl. now rewrite <- h. + easy. } rewrite <- h. exact (proj2_sig ind). Qed. (** Assuming that every [IList A] is parametric together with functional extensionality allow to recover the convenience of usual lists with the exception of fixed points. *) Require Import Coq.Logic.FunctionalExtensionality. Axiom ilist_param : forall (A:Set) (r:A⇔A) (l:IList A), Parametric r l. Corollary ilist_ind (A:Set) (P:IList A->Prop) (s:P empty) (f:forall (x:A) (l:IList A), P l -> P (cons x l)) (l:IList A) : P l. Proof. intros **. apply ilist_param_ind; try solve[easy|apply ilist_param]. intros **. extensionality R; extensionality c; extensionality e. easy. Qed. Lemma fold_right_empty (A B:Set) (f:A->B->B) (s:B) : fold_right f s empty = s. Proof. reflexivity. Qed. Lemma fold_right_cons (A B:Set) (f:A->B->B) (s:B) x l : fold_right f s (cons x l) = f x (fold_right f s l). Proof. reflexivity. Qed. Theorem ilist_rec0_empty (A B:Set) (s:B) (f:A->IList A -> B -> B) : ilist_rec0 s f empty = s. Proof. reflexivity. Qed. (** Contrary to the case true inductive type, this property needs to be proven by induction. *) Theorem ilist_rec0_cons (A B:Set) (s:B) (f:A->IList A -> B -> B) x l : ilist_rec0 s f (cons x l) = f x l (ilist_rec0 s f l). Proof. unfold ilist_rec0. simpl. f_equal. clear. induction l as [ | x l h ] using ilist_ind. + easy. + simpl. congruence. Qed. Remark conj_injective (A:Set) (x₁ x₂:A) (l₁ l₂:IList A) : cons x₁ l₁ = cons x₂ l₂ -> x₁ = x₂ /\ l₁ = l₂. Proof. intros h. split. + apply (f_equal (ilist_rec0 x₁(*this x₁ is not used, it just fills the gap*) (fun a _ _ => a)) h). + (* The list case is harder because it does not reduce up to conversion. *) set (tl := (ilist_rec0 l₁ (fun _ l _ => l))). assert (forall l x, tl (cons x l) = l) as def. { clear. subst tl. intros **. rewrite ilist_rec0_cons. reflexivity. } rewrite <- (def l₁ x₁) , <- (def l₂ x₂). congruence. Qed.
- Re: [Coq-Club] Erasable Red/Black Trees in Coq, (continued)
- Re: [Coq-Club] Erasable Red/Black Trees in Coq, Arnaud Spiwack, 04/22/2014
- Re: [Coq-Club] Erasable Red/Black Trees in Coq, Jonathan, 04/23/2014
- Re: [Coq-Club] Erasable Red/Black Trees in Coq, AUGER Cédric, 04/23/2014
- Re: [Coq-Club] Erasable Red/Black Trees in Coq, Arnaud Spiwack, 04/23/2014
- Re: [Coq-Club] Erasable Red/Black Trees in Coq, Arnaud Spiwack, 04/24/2014
- Re: [Coq-Club] Erasable Red/Black Trees in Coq, Jonathan, 04/24/2014
- Re: [Coq-Club] Erasable Red/Black Trees in Coq, Jonathan, 04/26/2014
- Re: [Coq-Club] Erasable Red/Black Trees in Coq, AUGER Cédric, 04/26/2014
- Re: [Coq-Club] Erasable Red/Black Trees in Coq, Arnaud Spiwack, 04/28/2014
- Re: [Coq-Club] Erasable Red/Black Trees in Coq, Jason Gross, 04/28/2014
- Re: [Coq-Club] Erasable Red/Black Trees in Coq, Cedric Auger, 04/28/2014
