- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Question about Exhaustive Matches
- Date: Tue, 13 May 2014 16:19:21 +0200
What do you mean by "that isn't at the top
level of a definition"?
2014-05-13 16:07 GMT+02:00 Adam Chlipala <adamc AT csail.mit.edu>:
Thanks for a good example that I hope contributes further to convincing the Coq team to remove this confusing flavor of type inference for dependent [match]. :) I don't think there is a simple explanation of the behavior you see, and IMO it would be better to require a [return] annotation on every [match] (that isn't at the top level of a definition) giving the dependent typing scheme explicitly.
On 05/10/2014 04:29 PM, Jack Kolb wrote:In this case, I get the helpful error message: "Non exhaustive pattern-matching: no clause found for pattern 1." However, something strange happens when I make a similar mistake in the second of the two definitions given above:
Definition nat_ind3: forall (P : nat -> Prop),P 0 -> P 1 -> P 2 ->(forall n : nat, P n -> P (S (S (S n)))) ->forall n : nat, P n :=fun P => fun P0 => fun P1 => fun P2 => fun PSSS =>fix f (n:nat) := match n with0 => P0| 1 => P1| (S (S (S n'))) => PSSS n' (f n')end.
In this case, I get the following error message:
In environmentP : nat -> PropP0 : P 0P1 : P 1P2 : P 2PSSS : forall n : nat, P n -> P (S (S (S n)))f : nat -> P 0n : natn0 : natThe term "P1" has type "P 1" while it is expected to have type "P 0".
.../Sedrikov\...
- [Coq-Club] Question about Exhaustive Matches, Jack Kolb, 05/10/2014
- Re: [Coq-Club] Question about Exhaustive Matches, Beta Ziliani, 05/13/2014
- Re: [Coq-Club] Question about Exhaustive Matches, Cedric Auger, 05/13/2014
- Re: [Coq-Club] Question about Exhaustive Matches, Adam Chlipala, 05/13/2014
- Re: [Coq-Club] Question about Exhaustive Matches, Jason Gross, 05/13/2014
