coq-club - Re: [Coq-Club] Question about Exhaustive Matches
  • To: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Question about Exhaustive Matches
  • Date: Tue, 13 May 2014 19:58:20 +0200
Here's a proposal: if we can fully infer the type of the [match] without inspecting it, and [pattern <match discriminee> in <type of match>] succeeds (and a further patterning on the indices/parameters, if necessary), then the resulting function should be tried as a the motive of the match.
-Jason
On Tue, May 13, 2014 at 5:29 PM, Adam Chlipala <adamc AT csail.mit.edu> wrote:
On 05/13/2014 10:31 AM, Cedric Auger wrote:
2014-05-13 16:20 GMT+02:00 Adam Chlipala <adamc AT csail.mit.edu>:
I suggest that it is appropriate to elaborate the following code:
    Definition foo (n : nat) : T n := match n with ... end.
into:
    Definition foo (n : nat) : T n := match n return T n with ... end.
but that further cleverness does more harm than good.
Well, don’t you rather want to allow that when the overall type of the match is provided?
Well, in short, no. :-)  It's hard for me to see a simple, elegant rule that covers your examples.
I mean a:
Definition foo … := … ((fun x : <some explicit type> => …) match … end) …
or a
Definition foo … := … (match … end : <some explicit type>) …
would be allowed, but not
Definition foo (n : nat) := match n with … end.
(This is your example, but this time the ": T n" is not provided.)
