coq-club - Re: [Coq-Club] Question about Exhaustive Matches
  • To: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Question about Exhaustive Matches
  • Date: Tue, 13 May 2014 16:31:20 +0200
2014-05-13 16:20 GMT+02:00 Adam Chlipala <adamc AT csail.mit.edu>:
I suggest that it is appropriate to elaborate the following code:
    Definition foo (n : nat) : T n := match n with ... end.
into:
    Definition foo (n : nat) : T n := match n return T n with ... end.
but that further cleverness does more harm than good.
Well, don’t you rather want to allow that when the overall type of the match is provided? I mean a:
Definition foo … := … ((fun x : <some explicit type> => …) match … end) …
or a
Definition foo … := … (match … end : <some explicit type>) …
would be allowed, but not
Definition foo (n : nat) := match n with … end.
(This is your example, but this time the ": T n" is not provided.)
On 05/13/2014 10:19 AM, Cedric Auger wrote:
What do you mean by "that isn't at the top level of a definition"?
2014-05-13 16:07 GMT+02:00 Adam Chlipala <adamc AT csail.mit.edu>:
Thanks for a good example that I hope contributes further to convincing the Coq team to remove this confusing flavor of type inference for dependent [match]. :)  I don't think there is a simple explanation of the behavior you see, and IMO it would be better to require a [return] annotation on every [match] (that isn't at the top level of a definition) giving the dependent typing scheme explicitly.
.../Sedrikov\...
