coq-club - Re: [Coq-Club] Question about Exhaustive Matches
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Question about Exhaustive Matches
  • Date: Thu, 22 May 2014 17:28:35 -0500
I guess I don't quite understand this explanation---it looks to me like there must be something a bit more idiosyncratic about the type inference process. Amongst the several code fragments that Jack had in his message, this one
Definition nat_ind3: forall (P : nat -> Prop),
  P 0 -> P 1 -> P 2 ->
  (forall n : nat, P n -> P (S (S (S n)))) ->
  forall n : nat, P n :=
    fun P => fun P0 => fun P1 => fun P2 => fun PSSS =>
      fix f (n:nat) := match n with
         0 => P0
       | 1 => P1
       | 2 => P2
       | (S (S (S n'))) => PSSS n' (f n')
     end.
does not encounter a type error whereas this one
         0 => P0
       | 1 => P1
     end.
encounters the type error that you have provided an explanation for. However, both of these look similar from a typing perspective. Of course, the second has a problem in that the function is not total but this is a different issue, not related to type inference.
Why does the difference between the intended type and the inferred type show up only in one case and not the other?
(For the record, I probably agree with Adam in his observation that requiring an explicit type is better than inferring one and getting it wrong in a confusing way, but I there is still something puzzling about this example.)
-Gopalan
On Tue, May 13, 2014 at 6:45 AM, Cedric Auger <sedrikov AT gmail.com> wrote:
2014-05-10 22:29 GMT+02:00 Jack Kolb <kolb0128 AT umn.edu>:
Hi,
I am working though Software Foundations and have a question on a topic included in the "MoreInd" chapter. The text discusses the idea of defining and using alternate means of induction over certain types. For example, it gives the following definition that can be used to perform induction over natural numbers:
Definition nat_ind2: forall (P : nat -> Prop),
  P 0 -> P 1 ->
  (forall n : nat, P n -> P (S (S n))) ->
    fun P => fun P0 => fun P1 => fun PSS =>
         0 => P0
       | 1 => P1
       | (S (S n')) => PSS n' (f n')
     end.
Just for fun, I experimented with this definition a bit. Coq will accept the following similar definition.
         0 => P0
       | 1 => P1
       | 2 => P2
     end.
In both cases, Coq is able to determine that the function f is total, i.e. that the provided clauses cover all possible inputs. Things get interesting when I intentionally omit a clause, like so:
  P 0 -> P 1 ->
         0 => P0
     end.
In this case, I get the helpful error message: "Non exhaustive pattern-matching: no clause found for pattern 1." However, something strange happens when I make a similar mistake in the second of the two definitions given above:
         0 => P0
       | 1 => P1
     end.
In this case, I get the following error message:
In environment
P : nat -> Prop
P0 : P 0
P1 : P 1
P2 : P 2
PSSS : forall n : nat, P n -> P (S (S (S n)))
f : nat -> P 0
n : nat
n0 : nat
The term "P1" has type "P 1" while it is expected to have type "P 0".
It seems Coq has conjectured that f has the type nat -> P 0, which seems very strange. I am very curious about why this occurs. Could someone perhaps explain what is going on internally when Coq attempts to check for exhaustive pattern matching, and why this situation in particular causes this kind of problem?
Thanks!
I guess that it is due to the "extended pattern matching inference" (I don’t know how to call that).
What you intended to write was:
      fix f (n:nat) := match n as N in _ return P N with
         0 => P0 (*Type checks*)
       | 1 => P1 (*Type checks*)
       | (S (S (S n'))) => PSSS n' (f n')  (*Type checks*)
     end.
and what Coq infered:
      fix f (n:nat) := match n as N in _ return P O with
       | 1 => P1 (*Type error*)
       | (S (S (S n'))) => PSSS n' (f n')  (*Type error*)
     end.
This is due to the fact that inference of annotations are done by typing branches.
The "0 => P0" branch infers that the type to be inferred is "P O" but in fact, but what you want is in fact "P n" where 'n' is the value to be matched, so it fits for the other branches as well.
.../Sedrikov\...
