Re: [Coq-Club] Ending a section and its dependency analysis of global objects in it
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Ending a section and its dependency analysis of global objects in it
- Date: Wed, 25 Jun 2014 20:24:43 -0400
On 06/25/2014 07:21 PM, Jason Gross wrote:
Are you looking for something like this?
Jason,
I am in looking for a solution that isn't like "abstract tac" - it should instead allow for separate interactive solution of the goal being abstracted. The techniques you show here look quite interesting, but I don't see how they could apply if the goal is to be interactively solved instead of solved via a single tactic.
-- Jonathan
Tactic Notation "test" tactic3(tac) :=
try (first [ tac | fail 2 tac "does not succeed" ]; fail tac "succeeds";
[](* test for [t] solved all goals *)).
(** [not tac] is equivalent to [fail tac "succeeds"] if [tac] succeeds, and
is equivalent to [idtac] if [tac] fails *)
Tactic Notation "not" tactic3(tac) := try ((test tac); fail 1 tac
"succeeds").
(** [revert_last] and [reverse] are taken from [Coq.Program.Program] *)
Ltac revert_last :=
match goal with
| [ H : _ |- _ ] => revert H
end.
Ltac reverse := repeat revert_last.
Ltac goal_has_evars :=
let G := match goal with |- ?G => constr:(G) end in
has_evar G.
(** Clear any hypotheses that aren't needed to solve the goal by [intros;
tac], and then revert all remaining hypotheses *)
Ltac prepare_for_solving_by tac :=
first [ test solve [ intros; tac ]
| fail "The goal cannot be solved by intros;" tac ];
first [ not goal_has_evars
| fail "prepare_for_solving_by does not handle evars" ];
intros;
repeat match goal with
| [ H : _ |- _ ] => clear H; test solve [ intros; tac ]
end;
reverse.
(** Like [intros; abstract tac], but the resulting opaque proof term won't
depend on any hypotheses it doesn't need. Note that the time this takes is
something like O((number of clearable hypotheses + 1) * (number of
unclearable hypotheses + 1) * time of running [tac]) *)
Ltac clear_abstract tac :=
prepare_for_solving_by tac;
intros; abstract tac.
Require Import Omega.
Goal forall (n m q : nat), n + m = m + n.
intros.
prepare_for_solving_by omega.
(* [forall n m : nat, n + m = m + n] *)
- [Coq-Club] Ending a section and its dependency analysis of global objects in it, Jonathan, 06/24/2014
- Re: [Coq-Club] Ending a section and its dependency analysis of global objects in it, Guillaume Melquiond, 06/25/2014
- Re: [Coq-Club] Ending a section and its dependency analysis of global objects in it, Cedric Auger, 06/25/2014
- Re: [Coq-Club] Ending a section and its dependency analysis of global objects in it, Jonathan, 06/25/2014
- Re: [Coq-Club] Ending a section and its dependency analysis of global objects in it, Jason Gross, 06/26/2014
- Re: [Coq-Club] Ending a section and its dependency analysis of global objects in it, Jonathan, 06/26/2014
- Re: [Coq-Club] Ending a section and its dependency analysis of global objects in it, AUGER Cédric, 06/26/2014
