coq-club - Re: [Coq-Club] Ending a section and its dependency analysis of global objects in it
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Ending a section and its dependency analysis of global objects in it
  • Date: Wed, 25 Jun 2014 13:42:20 -0400
On 06/25/2014 03:51 AM, Cedric Auger wrote:
I cannot test here, but isn’t there any distinction on whether or not the
term defined in section is opaque?
I tried both Qed and Defined - the results are the same. And, yes, printing the proof term (which is enormous, in comparison to the proof script and the extracted OCaml code) does show the "mistaken" dependencies. I think they may be due to use of inversion tactics. The type of one of the problematic section variables doesn't (and can't) come up at any point during the proof - so it can't be used by assumption or auto - but it shows up in the proof term as actual arguments to the many nested levels of anonymous functions that I think are generated by inversion.
Those nested anonymous functions in the proof term are the artifact of inversion automating the "convoy" pattern, correct? I am glad I am not doing that by hand. I read about the convoy pattern in Adam Chlipala's book, and would not have attempted further use of Coq had I not found the inversion tactic to use in place of hand-coding convoy patterns.
-- Jonathan
2014-06-25 8:29 GMT+02:00 Guillaume Melquiond
<guillaume.melquiond AT inria.fr>
On 24/06/2014 23:53, Jonathan wrote:
Could someone describe in more detail what is supposed to go on at the
end of a section with regard to this dependency analysis? I might be
seeing a bug, or I might just not understand what is involved in a
dependency according to this analysis. Is it perhaps that some tactics
involved in the proof of the definition create "false" dependencies that
aren't really needed, but are still honored with respect to
end-of-section dependency analysis?
As long as the hypotheses appear in the constructed proof terms, they are
actual dependencies. You can Print the proved theorems to see where they
come from. Do you happen to use any automatic tactic (auto, omega,
assumption, etc)? Such tactics don't try to find the minimal subset of
hypotheses needed for proving a goal. And even if they were doing this
extra work locally, that would not guarantee that the whole theorem would
use a minimal subset of hypotheses.
Best regards,
Guillaume
