[Coq-Club] Fwd: Re: Ending a section and its dependency analysis of global objects in it
- To: Coq Club <coq-club AT inria.fr>
- Subject: [Coq-Club] Fwd: Re: Ending a section and its dependency analysis of global objects in it
- Date: Thu, 26 Jun 2014 11:36:28 -0400
[oops - I hit reply instead of reply-list - forwarding...] -------- Original Message -------- Subject: Re: [Coq-Club] Ending a section and its dependency analysis of global objects in it Date: Thu, 26 Jun 2014 11:35:04 -0400 From: Jonathan <jonikelee AT gmail.com> To: AUGER Cédric <sedrikov AT gmail.com> On 06/26/2014 03:39 AM, AUGER Cédric wrote: > Of course, having interactive abstract would be way better. I think the problems I was having with Sections just means that one shouldn't use Sections for interactive abstract - so here's an alternative proposal: Given a goal that does not contain evars, use emacs to turn the goal into a definition that is introduced into the current script just prior to the definition that produced the goal - and initially prove this new definition with admit. That requires undoing back in the script - but once the new definition is proved via admit, one can roll forward back to the originating goal. Then, prove that goal using eapply Foo; assumption (assuming Foo is the name chosen for the abstracted-out definition) - so that which actual arguments end up being used by Foo is not hard-wired into the proof script. Or, if you can tolerate definitions in the middle of other definitions (Coq allows them - but does anyone use this feature?), the roll-back-roll-forward steps can be omitted, and the new abstracted-out definition gets inserted right in-line of the current proof script at the point of the goal it abstracts. Later, prove Foo (in place of admitting it). Then, apply another emacs function on that definition that deletes its arguments one at a time starting with the last and working backwards - each time checking if Foo can still be proven with the given script. This is basically a "meta-ized" version of what Jason has done for abstract, using emacs instead of Ltac to do the dependency filtering (that I had wished Section would already be doing). I am not an accomplished emacs hacker, but this doesn't seem like it would require much... -- Jonathan |
- [Coq-Club] Fwd: Re: Ending a section and its dependency analysis of global objects in it, Jonathan, 06/26/2014
