- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Can´t understand error message for apply
- Date: Thu, 26 Jun 2014 09:00:01 -0300
Hi Marcus,
I have not tested your code, but it seems that using destruct (foo1 _ _ H) as [H1 | H2], should work.
Regards.
Rodrigo
On Thu, Jun 26, 2014 at 7:18 AM, Marcus Ramos <marcus.ramos AT univasf.edu.br> wrote:
Hi,This should be obvious, but still I can´t see why it doesn´t work. In the script:Lemma foo1:forall (i j: nat), i=j -> (forall p q: nat, p <= q \/ p > q).Proof.Admitted.
Lemma foo2:forall (m n: nat),m = n -> n = m.Proof.intros m n H.apply foo1 in H.Why does the "apply foo1 in H" above causes the folowing error message to be displayed?
"Error: Unable to find an instance for the variables p, q."
Shouldn´t it just place (forall p q: nat, p <= q \/ p > q) in the context as a new hypothesis? If I execute, for example, apply foo1 with (p:=0)(q:=1) in H, I get H : 0 <= 1 \/ 0 > 1, but this is not what I want.Thanks,Marcus.
- [Coq-Club] Can´t understand error message for apply, Marcus Ramos, 06/26/2014
- <Possible follow-up(s)>
- Re: [Coq-Club] Can´t understand error message for apply, Rodrigo Ribeiro, 06/26/2014
