Re: [Coq-Club] Existential Instantiation and the relationship between classical and constructive logic.
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Existential Instantiation and the relationship between classical and constructive logic.
- Date: Thu, 26 Jun 2014 12:57:32 -0400
On 06/25/2014 02:17 PM, Larry D. Lee jr. wrote:
I've been working on a problem in which, given some predicate, P : A -> Prop, I can prove that there exists some value, x : A, that satisfies P (I.E. P x).
This development occurred within the context of a module and I wanted to say something like: "There exists a value x : A, such that P x. ... Let K represent a value that satisfies P (we know that K exists because...). ...". The second part of this statement is an instance of existential instantiation.
In Gallina, it is possible to represent existential instantiation, it corresponds to ex's inductive property (ex_ind : forall (A : Type) (P : A -> Prop) (P0 : Prop), (forall x : A, P x -> P0) -> ex P -> P0). Specifically, the existentially quantified variable x is instantiated in P0's context ("forall x : A, P x -> P0"). My problem was that I wanted to instantiate an existentially quantified variable at the global level and use the variable in subsequent calculations.
I am not sure I understand your requirements here. Do you want to assert both K as a witness to A and "There exists a value x:A such that P x" where K is one such value as global hypotheses? That can be done in Gallina using a Variable and a Hypothesis:
Variable K : A.
Hypothesis PK : P K.
Ex's definition seemed to prohibit me from doing this. So I changed the return type in ex's definition from Prop to Type producing:
Inductive ex2 (A : Type) (P : A -> Prop) : Type :=
ex2_intro : forall x : A, P x -> ex2 P.
That type already exists in Coq - it is called sig. There is a whole family of these exist-like quantifier/inductives in Coq.Init.Specif.
-- Jonathan
- [Coq-Club] Remove or update a canonical structure registration?, Peng Wang, 06/18/2014
- Re: [Coq-Club] Remove or update a canonical structure registration?, Beta Ziliani, 06/18/2014
- Re: [Coq-Club] Remove or update a canonical structure registration?, Pierre-Marie Pédrot, 06/18/2014
- Re: [Coq-Club] Remove or update a canonical structure registration?, Strub, Pierre-Yves, 06/23/2014
- Re: [Coq-Club] Remove or update a canonical structure registration?, Peng Wang, 06/25/2014
- Message not available
- [Coq-Club] Existential Instantiation and the relationship between classical and constructive logic., Larry D. Lee jr., 06/25/2014
- Re: [Coq-Club] Existential Instantiation and the relationship between classical and constructive logic., Jonathan, 06/26/2014
