coq-club - [Coq-Club] Parametric Morphisms
  • From: Durward McDonell <Durward.McDonell AT jhuapl.edu>
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] Parametric Morphisms
  • Date: Mon, 07 Jul 2014 14:32:34 -0400
Hello.
Here's what I understand: suppose you have two types, "expr" and
"state". Also suppose you have
eq_expr : state -> expr -> expr -> Prop
and that you Add (eq_expr st) as a reflexive, symmetric, and
transitive Parametric Relation for all (st : state). Finally, suppose
you have
foo : state -> expr -> expr -> Prop
that respects eq_expr on both of its expr arguments. Then you can
do
Add Parametric Morphism (st : state) :
(foo st)
with signature ((eq_expr st) ==> (eq_expr st) ==> impl)
as foo_mor.
Subsequently, if you have
H : foo st e f
G : eq_expr st e e'
you can use "rewrite G in H" to get
H : foo st e' f
So far, so good, I hope. My question is what if, for some perverse
reason, you really, really want foo to be
foo' : expr -> expr -> state -> Prop
that is, you just want to reorder the arguments to foo. What do you do
about the Parametric Morphism statement? I've tried a couple of things
that were either unsatisfactory, or simply didn't work. Any suggestion
would be welcome.
Durward McDonell
durward.mcdonell AT jhuapl.edu
240-228-2690 (DC)
443-778-2690 (Balt.)
Attachment: smime.p7s
Description: S/MIME Cryptographic Signature
