- From: Durward McDonell <Durward.McDonell AT jhuapl.edu>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Parametric Morphisms
- Date: Tue, 08 Jul 2014 10:33:06 -0400
On 07/08/2014 10:18 AM, Jason Gross wrote:
> Can you do
> Notation foo' e f := (fun st => foo st e f).
> and carry around a (foo' e f)?
Yes! That was one of my solutions. It works, but the drawback is
always having to convert between foo and foo' when you want to do
rewrites. Or wait -- you said use Notation, while my solution was
to define foo' as an auxiliary function. Does Notation make rewriting
transparent? In any case, maybe there's a clever way to us ltac for
whatever's needed? I'm not that great with ltac yet.
I'll have to go fiddle with this and see if it does what I want.
Thanks!
Durward
> On Tue, Jul 8, 2014 at 3:05 PM, Durward McDonell
> <mailto:Durward.McDonell AT jhuapl.edu>>
> wrote:
> That's not a bad idea, but we really want to carry around
> (foo e f) and apply it to a state. But given a fixed state,
> we want to be able to switch e' and f' in for e and f when
> appropriate.
> Thanks for the reply.
> Durward
> On 07/08/2014 04:05 AM, Cedric Auger wrote:
> > Maybe you could define a notation to change the order the
> arguments are
> > parsed/printed and in fact use the expected order for "Parametric
> Morphism".
> > 2014-07-07 20:32 GMT+02:00 Durward McDonell
> <mailto:Durward.McDonell AT jhuapl.edu>>>:
> > Hello.
> > Here's what I understand: suppose you have two types, "expr" and
> > "state". Also suppose you have
> > eq_expr : state -> expr -> expr -> Prop
> > and that you Add (eq_expr st) as a reflexive, symmetric, and
> > transitive Parametric Relation for all (st : state). Finally,
> suppose
> > you have
> > foo : state -> expr -> expr -> Prop
> > that respects eq_expr on both of its expr arguments. Then you can
> > do
> > Add Parametric Morphism (st : state) :
> > (foo st)
> > with signature ((eq_expr st) ==> (eq_expr st) ==> impl)
> > as foo_mor.
> > Subsequently, if you have
> > H : foo st e f
> > G : eq_expr st e e'
> > you can use "rewrite G in H" to get
> > H : foo st e' f
> > So far, so good, I hope. My question is what if, for some perverse
> > reason, you really, really want foo to be
> > foo' : expr -> expr -> state -> Prop
> > that is, you just want to reorder the arguments to foo. What
> do you do
> > about the Parametric Morphism statement? I've tried a couple
> of things
> > that were either unsatisfactory, or simply didn't work. Any
> suggestion
> > would be welcome.
> > Durward McDonell
> durward.mcdonell AT jhuapl.edu
> <mailto:durward.mcdonell AT jhuapl.edu>
> <mailto:durward.mcdonell AT jhuapl.edu>>
> > 240-228-2690 <tel:240-228-2690> <tel:240-228-2690
> <tel:240-228-2690>> (DC)
> > 443-778-2690 <tel:443-778-2690> <tel:443-778-2690
> <tel:443-778-2690>> (Balt.)
> > .../Sedrikov\...
> Durward McDonell
> 240-228-2690 <tel:240-228-2690> (DC)
> 443-778-2690 <tel:443-778-2690> (Balt.)
Durward McDonell
240-228-2690 (DC)
443-778-2690 (Balt.)
smime.p7s
Description: S/MIME Cryptographic Signature
- [Coq-Club] Parametric Morphisms, Durward McDonell, 07/07/2014
- Re: [Coq-Club] Parametric Morphisms, Cedric Auger, 07/08/2014
- Re: [Coq-Club] Parametric Morphisms, Durward McDonell, 07/08/2014
- Re: [Coq-Club] Parametric Morphisms, Jason Gross, 07/08/2014
- Re: [Coq-Club] Parametric Morphisms, Jason Gross, 07/10/2014
