coq-club - Re: [Coq-Club] Parametric Morphisms
  • To: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Parametric Morphisms
  • Date: Tue, 8 Jul 2014 10:05:58 +0200
Maybe you could define a notation to change the order the arguments are parsed/printed and in fact use the expected order for "Parametric Morphism".
2014-07-07 20:32 GMT+02:00 Durward McDonell <Durward.McDonell AT jhuapl.edu>:
Hello.
Here's what I understand: suppose you have two types, "expr" and
"state". Also suppose you have
eq_expr : state -> expr -> expr -> Prop
and that you Add (eq_expr st) as a reflexive, symmetric, and
transitive Parametric Relation for all (st : state). Finally, suppose
you have
foo : state -> expr -> expr -> Prop
that respects eq_expr on both of its expr arguments. Then you can
do
Add Parametric Morphism (st : state) :
    (foo st)
    with signature ((eq_expr st) ==> (eq_expr st) ==> impl)
    as foo_mor.
Subsequently, if you have
H : foo st e f
G : eq_expr st e e'
you can use "rewrite G in H" to get
H : foo st e' f
So far, so good, I hope. My question is what if, for some perverse
reason, you really, really want foo to be
foo' : expr -> expr -> state -> Prop
that is, you just want to reorder the arguments to foo. What do you do
about the Parametric Morphism statement? I've tried a couple of things
that were either unsatisfactory, or simply didn't work. Any suggestion
would be welcome.
Durward McDonell
durward.mcdonell AT jhuapl.edu
240-228-2690 (DC)
443-778-2690 (Balt.)
.../Sedrikov\...
