coq-club - Re: [Coq-Club] Smart case analysis in Coq.
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Smart case analysis in Coq.
  • Date: Sun, 20 Jul 2014 10:05:48 -0400
On 07/20/2014 06:06 AM, Kirill Taran wrote:
If you are instead asking for a tactic to replace the above assertion
such that it determines the type of H' for you, I agree that such a tactic
would be nice to have.
This and plus that with some matches we need more than one destruct (when
patterns have variables e.g.), but the latter can be fixed with plain repeat
Maybe there are other difficulties with complex pattern matches, yesterday
I had some specific notes, but I have forgotten them already =/
Sincerely,
Kirill Taran
I don't mind having to compose destructs. But, there is one variant of the assert X as H' by (destruct P...) that would be very useful to have as a tactic - which is when P is a Prop but the current goal is not (and so P cannot be case analyzed in the current goal at all), and the type X one would get by destructing P is too complex to determine by hand prior to interactively destructing P. In such a case, a workaround is to do something like exfalso (producing a goal in Prop), then destruct P, then copy out the result, then undo to before the exfalso, then assert (pasted result) as H' by (destruct P...). I call this "Prop smuggling", and it is something I do often enough that I have attempted to automated it, but it is exceedingly difficult to automate in a general way. The closest I have come is a tactic that uses an evar (R : Prop), then asserts the evar, then destructs P and instantiates R's value as the resulting logical type obtained from P. I can get this to work when P either destructs (or inverts) into a single subgoal, or into several such that all but one can be eliminated due to a contradiction. But, if P produces more than one non-contradictory subgoal, as in your case, and you want the result to be a disjunction of the types produced in each subgoal, then it's back to exfalso/destruct/copy/undo/paste by hand.
-- Jonathan
