- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Smart case analysis in Coq.
- Date: Sun, 20 Jul 2014 17:10:56 -0400
On 07/20/2014 04:34 PM, Jason Gross wrote:
If your goal is an evar in Prop, I think you can split it in to two evars
via [refine (_ : _ \/ _)]. Does this work (I'm not in fromt of a computer
at the moment), and if so, does it let you write the fully general tactic
you want?
-Jason
That's a nice trick! I wonder how it can be used here? One problem is that the inversion of the targeted Prop is going to do subgoal splitting itself. The other problem is that it is hard to know in advance how many subgoals are going to get created.
Maybe [instantiate (1:=_\/_) in (Value of P)] is a better choice - since it does the same evar splitting without splitting off subgoals - so that the inversion of the targeted Prop would be the only thing creating new subgoals.
Hmmm.... Maybe this CAN be turned into a general version...
On Jul 20, 2014 3:06 PM, "Jonathan"
<jonikelee AT gmail.com>
wrote:
On 07/20/2014 06:06 AM, Kirill Taran wrote:
If you are instead asking for a tactic to replace the above assertionI don't mind having to compose destructs. But, there is one variant of
such that it determines the type of H' for you, I agree that such a tactic
would be nice to have.
This and plus that with some matches we need more than one destruct (when
patterns have variables e.g.), but the latter can be fixed with plain
repeat
Maybe there are other difficulties with complex pattern matches, yesterday
I had some specific notes, but I have forgotten them already =/
Sincerely,
Kirill Taran
the assert X as H' by (destruct P...) that would be very useful to have as
a tactic - which is when P is a Prop but the current goal is not (and so P
cannot be case analyzed in the current goal at all), and the type X one
would get by destructing P is too complex to determine by hand prior to
interactively destructing P. In such a case, a workaround is to do
something like exfalso (producing a goal in Prop), then destruct P, then
copy out the result, then undo to before the exfalso, then assert (pasted
result) as H' by (destruct P...). I call this "Prop smuggling", and it is
something I do often enough that I have attempted to automated it, but it
is exceedingly difficult to automate in a general way. The closest I have
come is a tactic that uses an evar (R : Prop), then asserts the evar, then
destructs P and instantiates R's value as the resulting logical type
obtained from P. I can get this to work when P either destructs (or
inverts) into a single subgoal, or into several such that all but one can
be eliminated due to a contradiction. But, if P produces more than one
non-contradictory subgoal, as in your case, and you want the result to be a
disjunction of the types produced in each subgoal, then it's back to
exfalso/destruct/copy/undo/paste by hand.
-- Jonathan
- [Coq-Club] Smart case analysis in Coq., Kirill Taran, 07/19/2014
- Re: [Coq-Club] Smart case analysis in Coq., Jonathan, 07/19/2014
- Re: [Coq-Club] Smart case analysis in Coq., Kirill Taran, 07/20/2014
- Re: [Coq-Club] Smart case analysis in Coq., Jonathan, 07/20/2014
- Re: [Coq-Club] Smart case analysis in Coq., Jason Gross, 07/20/2014
