- From: Arnaud Spiwack <aspiwack AT lix.polytechnique.fr>
- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.)
- Date: Fri, 25 Jul 2014 13:55:07 +0200
Is the problem the syntax, or the code? You can already write a [solve evar e using tac] by throwing [tac] into [$(...)$], and then unifying [e] with the result. If it's the syntax, how about [unshelve e], which leaves you with one additional focused goal at the front?
The problem, I think, is avoiding goal duplication. Whenever I tried it had some unpleasant effect and I decided to avoid trying something hackish.
Also, by the way, is it intended that you have to inspect the hypotheses to get your hands on the name of the evar introduced by [refine (let e : T := _ in _)] in the second goal? That is, to get a fresh named evar as a goal, I do something likeLtac new_style_evar e T :=refine (let e' : T := _ in _);[| let e' := match goal with e' := _ |- _ => constr:(e') end inrename e' into e ].
You are right that this is a problem. I'm not sure how to solve that. I'll look into it soon.
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), (continued)
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Jonathan, 07/24/2014
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Arnaud Spiwack, 07/24/2014
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Jason Gross, 07/24/2014
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Arnaud Spiwack, 07/25/2014
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Jason Gross, 07/25/2014
