- To: Marcus Ramos <marcus.ramos AT univasf.edu.br>
- Cc: Jonathan <jonikelee AT gmail.com>, "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Rewrite does not work
- Date: Tue, 29 Jul 2014 18:02:47 +0200
2014-07-29 17:26 GMT+02:00 Marcus Ramos <marcus.ramos AT univasf.edu.br>:
For the "why", it is quite easy: Coq simply uses the induction principle (well, in fact a tweaked version which starts by a symmetry), which is basically a dependent pattern matching.
To simplify, "rewrite <- H." is almost the same as "case H.", and "rewrite H." is almost the same as "case (sym_equal H).".
Dependant pattern matching in Coq is syntactical, there is no unification/conversion involved. It has some advantages: it is more efficient, and more predictable. Furthermore, conversion can be tricky as Coq has features like coinductives for which normal forms are less clear. Rewrite didn’t make the conversion, since rewrite NEVER does any conversion (well for the basic one; for the Setoid one, I do not know the details), like case/destruct NEVER do any conversion.
Hi Jonathan, Auger and Enrico,Thanks a lot, you gave me the solution for my problem. First of all, yes, "sf" is globally defined:Definition sf: Type:= list (non_terminal + terminal).Second, I used an "unfold" before each rewrite as you suggested and now both rewrites work fine:
unfold sf in H7.rewrite H7.unfold sf in H9.rewrite H9.As a result, I have the goal as I wanted and I was able to finish my proof:
1 subgoalsg : cfgn : natl : list sfIHn : Datatypes.length (removelast l) >= 2 ->(forall i : nat,i <= Datatypes.length (removelast l) - 2 ->exists (left : non_terminal) (right s s' : sf),nth i (removelast l) [] = s ++ inl left :: s' /\nth (S i) (removelast l) [] = s ++ right ++ s' /\ rules g left right) ->sflist g (removelast l)H0 : Datatypes.length l = S nH1 : Datatypes.length l >= 2left : non_terminalright : sfs : sfs' : sfH6 : nth (Datatypes.length l - 2) l [] = s ++ inl left :: s'H7 : last l [] = s ++ right ++ s'H8 : rules g left rightH3 : Datatypes.length (removelast l) = nH : Datatypes.length (removelast l) < 2H5 : nth (S (Datatypes.length l - 2)) l [] = last l []H9 : removelast l = [s ++ inl left :: s']______________________________________(1/1)sflist g ([s ++ inl left :: s'] ++ [s ++ right ++ s'])I still don´t understand why Coq didn´t make the conversion in the first place, but I will try to study the other information you sent to me and get to the point.
Anyway, my script will look strange with apparently useless unfolds before these two rewrites. I guess I´ll have to add comments so that I and others can understand it in the future, but this doesn´t seem very natural. Unless, of course, display options are changed. But should it be like this?I´ll keep ssreflect in mind, thanks Enrico.With My Best Regards,Marcus.2014-07-28 22:08 GMT-03:00 Jonathan <jonikelee AT gmail.com>:
Marcus,On 07/28/2014 08:22 PM, Marcus Ramos wrote:
Hi Auger and Jonathan,
Thank you for the replies. When I change the settings, this is what I get:
1 subgoals
g : cfg
n : nat
l : list sf
IHn : ge (@Datatypes.length sf (@removelast sf l)) (S (S O)) ->
(forall i : nat,
le i (minus (@Datatypes.length sf (@removelast sf l)) (S (S O))) ->
@ex non_terminal
(fun left : non_terminal =>
@ex sf
(fun right : sf =>
@ex sf
(fun s : sf =>
@ex sf
(fun s' : sf =>
and
(@eq sf
(@nth sf i (@removelast sf l)
(@nil (sum non_terminal terminal)))
(@app (sum non_terminal terminal) s
(@cons (sum non_terminal terminal)
(@inl non_terminal terminal left) s')))
(and
(@eq sf
(@nth sf (S i) (@removelast sf l)
(@app (sum non_terminal terminal) right s')))
(rules g left right))))))) ->
sflist g (@removelast sf l)
H0 : @eq nat (@Datatypes.length sf l) (S n)
H1 : ge (@Datatypes.length sf l) (S (S O))
left : non_terminal
right : sf
s : sf
s' : sf
H6 : @eq sf
(@nth sf (minus (@Datatypes.length sf l) (S (S O))) l
H7 : @eq sf (@last sf l (@nil (sum non_terminal terminal)))
H3 : @eq nat (@Datatypes.length sf (@removelast sf l)) n
H : lt (@Datatypes.length sf (@removelast sf l)) (S (S O))
H5 : @eq sf
(@nth sf (S (minus (@Datatypes.length sf l) (S (S O)))) l
H9 : @eq (list sf) (@removelast sf l)
(@cons (list (sum non_terminal terminal))
(@nil (list (sum non_terminal terminal))))
sflist g
(@app (list (sum non_terminal terminal))
(@removelast (list (sum non_terminal terminal)) l)
(@last (list (sum non_terminal terminal)) l
(@nil (list (sum non_terminal terminal)))))
It seems that Coq, for some reason, changed "sf" in H7 for "(list (sum
non_terminal terminal))" in the goal, and perhaps this is why rewrite does
not work.
However, this is exactly the definition of "sf". Why things look different
when the settings are changed? Why did this happen and how do I fix it?
This is all very confusing for me.
Thanks again,
Marcus.
I don't see the definition of sf in the above goal - I guess it is defined globally. One possibility is that Coq didn't immediately notice the equivalence between sf and (list (sum non_terminal terminal)) on the attempted rewrite - although it certainly understands that they are equivalent in other places. In that case, what happens if you unfold sf in H7 and then retry the rewrite? I have seen cases where Coq gets confused in the presence of type aliases such as sf. In general, I have opted to use Notations instead of Definitions to make shorthand aliases for types, as Coq has no problems with notational aliases.
-- Jonathan
.../Sedrikov\...
- Re: [Coq-Club] Rewrite does not work, (continued)
- Re: [Coq-Club] Rewrite does not work, Jonathan, 07/27/2014
- Re: [Coq-Club] Rewrite does not work, Pierre-Marie Pédrot, 07/28/2014
- Re: [Coq-Club] Rewrite does not work, Marcus Ramos, 07/29/2014
- Re: [Coq-Club] Rewrite does not work, Cedric Auger, 07/29/2014
- Re: [Coq-Club] Rewrite does not work, Enrico Tassi, 07/29/2014
- Re: [Coq-Club] Rewrite does not work, Xavier Leroy, 07/30/2014
- Re: [Coq-Club] Rewrite does not work, Jonathan, 07/30/2014
- Re: [Coq-Club] Rewrite does not work, Xavier Leroy, 07/31/2014
- Re: [Coq-Club] Rewrite does not work, Laurence Rideau, 07/31/2014
- Message not available
