- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Rewrite does not work
- Date: Fri, 01 Aug 2014 11:02:48 -0400
On 08/01/2014 05:23 AM, Enrico Tassi wrote:
On Thu, Jul 31, 2014 at 04:28:31PM -0400, Jonathan wrote:
- Is there access to a development version that works with the trunk versionIt is there:
of Coq?
https://gforge.inria.fr/scm/viewvc.php/trunk/Saclay/Ssreflect/?root=coq-contribs
But don't use it in "production"
- As I recall, SSReflect relies considerably on revert/re-intro styleI'm not sure I understand what you mean by destroy evar instantiability.
patterns. Do the SSReflect versions of these destroy evar instantiability
as they do in vanilla Coq? I have been learning how to write Ltac tactics
that don't alter the context to the point where evars become uninstantiable
(as well as others that try to prevent uninstatiability) - and it seems like
SSReflect's style could make this harder rather than easier. Or, does
SSReflect have ways around this already?
An example of how fragile evar instantiability is in Coq:
Goal forall (n:nat), True.
intros.
evar (i:nat).
instantiate (1:=n) in (Value of i). (*this works*)
Abort.
intros.
evar (i:nat).
rename n into m. (*renaming blocks instantiation:*)
Fail instantiate (1:=m) in (Value of i).
Abort.
intros.
evar (i:nat).
revert n; intro n. (*even this blocks instantiation:*)
Fail instantiate (1:=n) in (Value of i).
Abort.
Ssr POV is that evars are constants, no ssr tactic should let you
instantiate them, but should not "destroy" them either. We hardly use
evars in our goals.
Perhaps the occurrence of evars is much more likely when using backward chaining.
-- Jonathan
- Re: [Coq-Club] Rewrite does not work, Enrico Tassi, 08/01/2014
- Re: [Coq-Club] Rewrite does not work, Matthieu Sozeau, 08/01/2014
- <Possible follow-up(s)>
- Re: [Coq-Club] Rewrite does not work, Jonathan, 08/01/2014
- Re: [Coq-Club] Rewrite does not work, Cedric Auger, 08/01/2014
- [Coq-Club] evil evars (was Re: Rewrite does not work), Jonathan, 08/01/2014
- Re: [Coq-Club] evil evars (was Re: Rewrite does not work), Matthieu Sozeau, 08/01/2014
- Re: [Coq-Club] evil evars (was Re: Rewrite does not work), Cédric, 08/02/2014
- Re: [Coq-Club] evil evars (was Re: Rewrite does not work), Jonathan, 08/02/2014
- Re: [Coq-Club] evil evars (was Re: Rewrite does not work), Daniel Schepler, 08/02/2014
