coq-club - Re: [Coq-Club] Coq's cofixpoint productivity checker
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Coq's cofixpoint productivity checker
  • Date: Wed, 20 Aug 2014 11:55:32 -0400
You are allowed to put some things between the constructor and the recursive call (like other constructors, lambdas, nested cofixpoints, match statements whose return predicate is a coinductive type) as long as they are constructions which can never hide non-productivity (as always, it is an approximation).
In your case, you have a fixpoint between the constructor and the recursive call, which is not safe in general. The following example due to Gimenez shows that it can break normalization:
CoInductive nats := Cons : nat -> nats -> nats.
Definition tl (x : nats) :=
match x with Cons _ tl => tl end.
Fail CoFixpoint f : nat -> nats :=
fix g (n : nat) :=
Cons n (match n with O => f (S n) | S m => tl (tl (g m)) end).
(* The following term would not have a normal form *)
Fail Eval compute in tl (f (S O)).
As soon as I find the time, I'll try to write down the current guard conditions of Coq for fixpoints and cofixpoints to improve the documentation.
Maxime.
On 08/20/2014 11:31 AM, Jason Gross wrote:
Hi,
Why does Coq not notice that the following definition is manifestly productive?
Require Import Coq.Lists.Streams.
Fixpoint stream_prepend_list {T} (ls : list T) (rest : Stream T) : Stream T :=
match ls with
| nil => rest
| cons x xs => Cons x (stream_prepend_list xs rest)
end.
CoFixpoint flatten_stream {T} (s : Stream (T * list T)) : Stream T :=
match s with
| Cons x xs => Cons (fst x) (stream_prepend_list (snd x) (flatten_stream xs))
end.
(* Error:
Recursive definition of flatten_stream is ill-formed.
In environment
flatten_stream : forall T : Type, Stream (T * list T) -> Stream T
T : Type
x : T * list T
xs : Stream (T * list T)
Sub-expression "stream_prepend_list (snd x) (flatten_stream T xs)" not in
guarded form (should be a constructor, an abstraction, a match, a cofix or a
recursive call).
Recursive definition is:
"fun (T : Type) (s : Stream (T * list T)) =>
match s with
| Cons x xs =>
Cons (fst x) (stream_prepend_list (snd x) (flatten_stream T xs))
end". *)
It seems that Coq doesn't want me to put anything between the recursive call and the constructor, but it's syntactically obvious that my definition is productive...
-Jason
