coq-club - Re: [Coq-Club] Strictly positive inductive types
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Strictly positive inductive types
  • Date: Thu, 04 Sep 2014 19:04:13 +0200
But this example is no longer positive. For all positive inductive types mu T, one can get the impredicative encoding with constructor and iterator in system F. One even only needs the existence of a "functorial action" of type forall A forall B. (A -> B) -> T A -> T B. Such a term can exists for trivial reasons even if A appears at negative positions in T A. But there may be no reasonable way to define a destructor. Similar observations can be made for system F^omega and inductive families, but there, the type of the "functorial action" has to be chosen properly since there are several possibilities, often with bad operational behaviour.
Ralph
Le 04/09/2014 18:45, Randy Pollack a écrit :
Ralph Matthes wrote:
[...] the very idea of such a constructor is already found in Section
4.3.2 of Christine Paulin's habilitation thesis of 1996).
That's Chapter 4, Section 4.3.2 .
Since Ralph brought up plain system F, recall that
Definition lam: forall (X:Prop), ((X -> X)-> X) -> (X -> X -> X) -> X.
checks in system F. I'm echoing Thorsten in pointing this out.
However, unlike strictly positive impredicative intersections, no
constructor is definable for the "constructor" (X -> X)-> X.
--Randy
On Thu, Sep 4, 2014 at 10:27 AM, Ralph Matthes
<Ralph.Matthes AT irit.fr>
wrote:
Maybe there are only very few use cases since there is no support. In plain
system F, there is no problem at all with positive but not strictly positive
inductive types. I exploited this in my TLCA 2001 paper "Parigot's Second
Order lambda-mu-Calculus and Inductive Types", with the inductive type #rho
that has a constructor S of type ((#rho -> bot) -> bot) -> #rho (i.e.,
elimination of double negation - as I understood later, the very idea of
such a constructor is already found in Section 4.3.2 of Christine Paulin's
habilitation thesis of 1996). In system F^omega, one can have positive
inductive families that are not recognized as strictly positive in the Coq
system. There, this is not a question of being twice on the left of an arrow
but rather of nesting of type transformations. This has been studied in
several papers, in particular profoundly in "Iteration and coiteration
schemes for higher-order and nested datatypes. Theor. Comput. Sci. 333(1-2):
3-66 (2005)" by Andreas Abel, Tarmo Uustalu and myself.
I would be happy to see "natural" algorithmic examples involving
non-strictly positive inductive types and families. As I wrote above, people
might not be encouraged to search for them if tool support is missing.
Best, Ralph
Le 04/09/2014 15:32, Maxime Dénès a écrit :
Hi,
Indeed, that's what I meant by "in general".
Note that Coq doesn't allow positive types that are not strictly positive
even when they are small, which probably makes it more conservative than it
could be. On the other hand, I don't know if there are many use cases that
are impacted.
Best,
Maxime.
On 09/04/2014 09:04 AM, Frédéric Blanqui wrote:
Hello.
Le 11/08/2014 23:23, Maxime Dénès a écrit :
Coq does reject non strictly positive types, even if they are positive.
Otherwise it would be inconsistent in general, as you could encode the
argument given in [1].
Non-strictly positive types are not necessarily inconsistent. In
Inductively defined types <http://dx.doi.org/10.1007/3-540-52335-9_47>,
COLOG'88, Thierry Coquand and Christine Paulin show that a particular "big"
non-strictly positive type is inconsistent (section 3.1, page 59). I call it
"big" for it has a constructor having a type argument that is not a
parameter. The constructor has type ((X->Prop)->Prop)->X. However, "small"
(e.g. replace Prop by bool) non-strictly positive types are harmless.
Best regards,
Frédéric.
I don't know of any flag to disable this check but a patch should not be
too hard to write. What's your use case?
Maxime.
[1] A new paradox in type theory, T. Coquand - Proceedings 9th Int.
Congress of Logic, Methodology, 1991
On 08/11/2014 05:04 PM, Luke Maurer wrote:
AFAIK, Coq always accepts types that are positive but not strictly so.
And it never accepts non-positive occurrences (unlike with Agda, Coq's
termination checking is mandatory).
- Luke
On Aug 11, 2014, at 1:54 PM,
<elilobo.v AT gmail.com>
wrote:
How to force Coq to accept non-strictly positive inductive types? Is
there a
flag like --no-positivity-check in Agda, to do it?
