- To: Coq-Club Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Strictly positive inductive types
- Date: Thu, 4 Sep 2014 12:45:25 -0400
Ralph Matthes wrote:
[...] the very idea of such a constructor is already found in Section
4.3.2 of Christine Paulin's habilitation thesis of 1996).
That's Chapter 4, Section 4.3.2 .
Since Ralph brought up plain system F, recall that
Definition lam: forall (X:Prop), ((X -> X)-> X) -> (X -> X -> X) -> X.
checks in system F. I'm echoing Thorsten in pointing this out.
However, unlike strictly positive impredicative intersections, no
constructor is definable for the "constructor" (X -> X)-> X.
--Randy
On Thu, Sep 4, 2014 at 10:27 AM, Ralph Matthes
<Ralph.Matthes AT irit.fr>
wrote:
> Maybe there are only very few use cases since there is no support. In plain
> system F, there is no problem at all with positive but not strictly positive
> inductive types. I exploited this in my TLCA 2001 paper "Parigot's Second
> Order lambda-mu-Calculus and Inductive Types", with the inductive type #rho
> that has a constructor S of type ((#rho -> bot) -> bot) -> #rho (i.e.,
> elimination of double negation - as I understood later, the very idea of
> such a constructor is already found in Section 4.3.2 of Christine Paulin's
> habilitation thesis of 1996). In system F^omega, one can have positive
> inductive families that are not recognized as strictly positive in the Coq
> system. There, this is not a question of being twice on the left of an arrow
> but rather of nesting of type transformations. This has been studied in
> several papers, in particular profoundly in "Iteration and coiteration
> schemes for higher-order and nested datatypes. Theor. Comput. Sci. 333(1-2):
> 3-66 (2005)" by Andreas Abel, Tarmo Uustalu and myself.
> I would be happy to see "natural" algorithmic examples involving
> non-strictly positive inductive types and families. As I wrote above, people
> might not be encouraged to search for them if tool support is missing.
> Best, Ralph
> Le 04/09/2014 15:32, Maxime Dénès a écrit :
>> Hi,
>> Indeed, that's what I meant by "in general".
>> Note that Coq doesn't allow positive types that are not strictly positive
>> even when they are small, which probably makes it more conservative than it
>> could be. On the other hand, I don't know if there are many use cases that
>> are impacted.
>> Best,
>> Maxime.
>> On 09/04/2014 09:04 AM, Frédéric Blanqui wrote:
>>> Hello.
>>> Le 11/08/2014 23:23, Maxime Dénès a écrit :
>>>> Coq does reject non strictly positive types, even if they are positive.
>>>> Otherwise it would be inconsistent in general, as you could encode the
>>>> argument given in [1].
>>> Non-strictly positive types are not necessarily inconsistent. In
>>> Inductively defined types <http://dx.doi.org/10.1007/3-540-52335-9_47>,
>>> COLOG'88, Thierry Coquand and Christine Paulin show that a particular
>>> "big"
>>> non-strictly positive type is inconsistent (section 3.1, page 59). I call
>>> it
>>> "big" for it has a constructor having a type argument that is not a
>>> parameter. The constructor has type ((X->Prop)->Prop)->X. However, "small"
>>> (e.g. replace Prop by bool) non-strictly positive types are harmless.
>>> Best regards,
>>> Frédéric.
>>>> I don't know of any flag to disable this check but a patch should not be
>>>> too hard to write. What's your use case?
>>>> Maxime.
>>>> [1] A new paradox in type theory, T. Coquand - Proceedings 9th Int.
>>>> Congress of Logic, Methodology, 1991
>>>> On 08/11/2014 05:04 PM, Luke Maurer wrote:
>>>>> AFAIK, Coq always accepts types that are positive but not strictly so.
>>>>> And it never accepts non-positive occurrences (unlike with Agda, Coq's
>>>>> termination checking is mandatory).
>>>>> - Luke
>>>>>> On Aug 11, 2014, at 1:54 PM,
>>>>>> <elilobo.v AT gmail.com>
>>>>>> wrote:
>>>>>> How to force Coq to accept non-strictly positive inductive types? Is
>>>>>> there a
>>>>>> flag like --no-positivity-check in Agda, to do it?
- Re: [Coq-Club] Strictly positive inductive types, Frédéric Blanqui, 09/04/2014
- Re: [Coq-Club] Strictly positive inductive types, Maxime Dénès, 09/04/2014
- Re: [Coq-Club] Strictly positive inductive types, Ralph Matthes, 09/04/2014
- Re: [Coq-Club] Strictly positive inductive types, Randy Pollack, 09/04/2014
- Re: [Coq-Club] Strictly positive inductive types, Thorsten Altenkirch, 09/04/2014
- Re: [Coq-Club] Strictly positive inductive types, Frédéric Blanqui, 09/08/2014
- Re: [Coq-Club] Strictly positive inductive types, Andrés Sicard-Ramírez, 09/05/2014
- Re: [Coq-Club] Strictly positive inductive types, Daniel Schepler, 09/05/2014
- <Possible follow-up(s)>
- Re: [Coq-Club] Strictly positive inductive types, J. Ian Johnson, 09/04/2014
- Re: [Coq-Club] Strictly positive inductive types, Thorsten Altenkirch, 09/05/2014
