- From: Frédéric Blanqui <frederic.blanqui AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Strictly positive inductive types
- Date: Thu, 04 Sep 2014 15:04:17 +0200
Hello. Le 11/08/2014 23:23, Maxime Dénès a
écrit :
Coq does reject non strictly positive types, even if they are positive. Otherwise it would be inconsistent in general, as you could encode the argument given in [1].Non-strictly positive types are not necessarily inconsistent. In Inductively defined types, COLOG'88, Thierry Coquand and Christine Paulin show that a particular "big" non-strictly positive type is inconsistent (section 3.1, page 59). I call it "big" for it has a constructor having a type argument that is not a parameter. The constructor has type ((X->Prop)->Prop)->X. However, "small" (e.g. replace Prop by bool) non-strictly positive types are harmless. Best regards, Frédéric. I don't know of any flag to disable this check but a patch should not be too hard to write. What's your use case? |
- Re: [Coq-Club] Strictly positive inductive types, Frédéric Blanqui, 09/04/2014
- Re: [Coq-Club] Strictly positive inductive types, Maxime Dénès, 09/04/2014
- Re: [Coq-Club] Strictly positive inductive types, Ralph Matthes, 09/04/2014
- Re: [Coq-Club] Strictly positive inductive types, Randy Pollack, 09/04/2014
- Re: [Coq-Club] Strictly positive inductive types, Thorsten Altenkirch, 09/04/2014
- Re: [Coq-Club] Strictly positive inductive types, Frédéric Blanqui, 09/08/2014
- Re: [Coq-Club] Strictly positive inductive types, Andrés Sicard-Ramírez, 09/05/2014
- Re: [Coq-Club] Strictly positive inductive types, Daniel Schepler, 09/05/2014
- <Possible follow-up(s)>
- Re: [Coq-Club] Strictly positive inductive types, J. Ian Johnson, 09/04/2014
