- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Universes
- Date: Fri, 5 Sep 2014 17:17:56 -0400
There is no inconsistency here. You are seeing the result of on-the-fly eta-expansion. Note that [Definition KKs := K (forall t:Set, t -> t) K.] is also accepted, because the eta-expansion of [K] can be retyped as [forall t:Set, t -> t]. If you [Print KK], you'll notice that it uses [Type (* Top.2 *)], and the universe graph contains the constraint "Top.2 < Top.1".
-Jason
On Fri, Sep 5, 2014 at 5:02 PM, Randy Pollack <rpollack AT inf.ed.ac.uk> wrote:
I'm using Coq 8.4pl4, which I think does not have Matthieu Sozeau's
new treatment of universes (is that true?). Consider the examples:
Definition I := fun (t:Type) (x:t) => x.
Definition II := I (forall t:Type, t -> t) I.
This is accepted, as it should be (by universe polymorphism), as the 2
instances of "I" in Definition II can get different types.
But consider
Set Printing Universes.
Parameter K : forall t:Type, t -> t.
Print K.
*** [ K : forall t : Type (* Top.1 *), t -> t ]
Print Universes
(* no constraint on Top.1 shown *)
So far, OK. But...
Check (K (forall t:Type, t -> t) K).
This is accepted, wrongly, as the 2 instances of "K" must have the same type.
Definition KK := K (forall t:Type, t -> t) K.
This is accepted, and now we have an ill-typed term bound in the global context.
--Randy
- [Coq-Club] Universes, Randy Pollack, 09/05/2014
- Re: [Coq-Club] Universes, Jason Gross, 09/05/2014
- Re: [Coq-Club] Universes, Matthieu Sozeau, 09/06/2014
- Re: [Coq-Club] Universes, Randy Pollack, 09/10/2014
- [Coq-Club] Fwd: Universes, Randy Pollack, 09/10/2014
- Re: [Coq-Club] Fwd: Universes, Matthieu Sozeau, 09/10/2014
- Re: [Coq-Club] Fwd: Universes, Randy Pollack, 09/10/2014
- Re: [Coq-Club] Fwd: Universes, Matthieu Sozeau, 09/11/2014
