- To: Coq-Club Club <coq-club AT inria.fr>
- Subject: [Coq-Club] Fwd: Universes
- Date: Tue, 9 Sep 2014 21:56:22 -0400
Oops, I was still composing that email
---------- Forwarded message ----------
<rpollack0 AT gmail.com>
Date: Tue, Sep 9, 2014 at 9:45 PM
Subject: Re: [Coq-Club] Universes
To: Coq-Club Club
Is there documentation of eta in Coq?
Consider this:
Definition T := Type. (* Fix a level *)
Parameter K : forall t:T, t -> t.
Lemma K_eta: K = (fun t:T => K t).
change (K = K). (* conversion contains eta *)
reflexivity.
Defined.
BTW, tactic [compute] doesn't eta expand the LHS of this lemma, or
contract the RHS.
Definition KK := K (forall t:Type, t -> t) K.
is accepted with eta-expansion of the second K, as Jason and Matthieu point
out.
Lemma xxx: KK = KK.
unfold KK.
rewrite K_eta at 2. (* fails *)
Toplevel input, characters 0-18:
Error: Illegal application (Type Error):
The term "K" of type "forall t : T, t -> t"
cannot be applied to the terms
"forall t : Type, t -> t" : "Type"
"fun t : T => K t" : "forall t : T, t -> t"
The 2nd term has type "forall t : T, t -> t" which should be coercible to
"forall t : Type, t -> t".
Why does rewriting by K_eta cause this Type Error?
Randy
On Sat, Sep 6, 2014 at 6:46 AM, Matthieu Sozeau
<matthieu.sozeau AT gmail.com>
wrote:
> Indeed, eta allows to lower the second I/K’s levels in your definitions.
> What’s impossible however is to use K at a type larger or equal to it’s
> declared universe.
> Fail Check (K (forall t:T, t -> t) K).
> All the examples you gave do not use polymorphism, but typical ambiguity +
> eta-expansion only. In 8.4, only Inductves like:
> Inductive I (A : Type(* l *)) : A -> Type (* l *) := i : A -> I
> can be “polymorphic” on A, that is you can instantiate I at
> different incompatible levels, all lower than the initial global
> level l.
> Hope this helps,
> — Matthieu
> On 5 sept. 2014, at 23:17, Jason Gross
> <jasongross9 AT gmail.com>
> wrote:
>> There is no inconsistency here. You are seeing the result of on-the-fly
>> eta-expansion. Note that [Definition KKs := K (forall t:Set, t -> t) K.]
>> is also accepted, because the eta-expansion of [K] can be retyped as
>> [forall t:Set, t -> t]. If you [Print KK], you'll notice that it uses
>> [Type (* Top.2 *)], and the universe graph contains the constraint "Top.2
>> < Top.1".
>> -Jason
>> On Fri, Sep 5, 2014 at 5:02 PM, Randy Pollack
>> <rpollack AT inf.ed.ac.uk>
>> wrote:
>> I'm using Coq 8.4pl4, which I think does not have Matthieu Sozeau's
>> new treatment of universes (is that true?). Consider the examples:
>> Definition I := fun (t:Type) (x:t) => x.
>> Definition II := I (forall t:Type, t -> t) I.
>> This is accepted, as it should be (by universe polymorphism), as the 2
>> instances of "I" in Definition II can get different types.
>> But consider
>> Set Printing Universes.
>> Parameter K : forall t:Type, t -> t.
>> Print K.
>> *** [ K : forall t : Type (* Top.1 *), t -> t ]
>> Print Universes
>> (* no constraint on Top.1 shown *)
>> So far, OK. But...
>> Check (K (forall t:Type, t -> t) K).
>> This is accepted, wrongly, as the 2 instances of "K" must have the same
>> type.
>> This is accepted, and now we have an ill-typed term bound in the global
>> context.
>> --Randy
- [Coq-Club] Universes, Randy Pollack, 09/05/2014
- Re: [Coq-Club] Universes, Jason Gross, 09/05/2014
- Re: [Coq-Club] Universes, Matthieu Sozeau, 09/06/2014
- Re: [Coq-Club] Universes, Randy Pollack, 09/10/2014
- [Coq-Club] Fwd: Universes, Randy Pollack, 09/10/2014
- Re: [Coq-Club] Fwd: Universes, Matthieu Sozeau, 09/10/2014
- Re: [Coq-Club] Fwd: Universes, Randy Pollack, 09/10/2014
- Re: [Coq-Club] Fwd: Universes, Matthieu Sozeau, 09/11/2014
