coq-club - Re: [Coq-Club] Universes
  • From: Matthieu Sozeau <matthieu.sozeau AT gmail.com>
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Universes
  • Date: Sat, 6 Sep 2014 12:46:28 +0200
Indeed, eta allows to lower the second I/K’s levels in your definitions.
What’s impossible however is to use K at a type larger or equal to it’s
declared universe.
Definition T := Type. (* Fix a level *)
Parameter K : forall t:T, t -> t.
Fail Check (K (forall t:T, t -> t) K).
All the examples you gave do not use polymorphism, but typical ambiguity +
eta-expansion only. In 8.4, only Inductves like:
Inductive I (A : Type(* l *)) : A -> Type (* l *) := i : A -> I
can be “polymorphic” on A, that is you can instantiate I at
different incompatible levels, all lower than the initial global
level l.
Hope this helps,
— Matthieu
On 5 sept. 2014, at 23:17, Jason Gross
<jasongross9 AT gmail.com>
wrote:
> There is no inconsistency here. You are seeing the result of on-the-fly
> eta-expansion. Note that [Definition KKs := K (forall t:Set, t -> t) K.]
> is also accepted, because the eta-expansion of [K] can be retyped as
> [forall t:Set, t -> t]. If you [Print KK], you'll notice that it uses
> [Type (* Top.2 *)], and the universe graph contains the constraint "Top.2 <
> Top.1".
> -Jason
> On Fri, Sep 5, 2014 at 5:02 PM, Randy Pollack
> <rpollack AT inf.ed.ac.uk>
> wrote:
> I'm using Coq 8.4pl4, which I think does not have Matthieu Sozeau's
> new treatment of universes (is that true?). Consider the examples:
> Definition I := fun (t:Type) (x:t) => x.
> Definition II := I (forall t:Type, t -> t) I.
> This is accepted, as it should be (by universe polymorphism), as the 2
> instances of "I" in Definition II can get different types.
> But consider
> Set Printing Universes.
> Parameter K : forall t:Type, t -> t.
> Print K.
> *** [ K : forall t : Type (* Top.1 *), t -> t ]
> Print Universes
> (* no constraint on Top.1 shown *)
> So far, OK. But...
> Check (K (forall t:Type, t -> t) K).
> This is accepted, wrongly, as the 2 instances of "K" must have the same
> type.
> Definition KK := K (forall t:Type, t -> t) K.
> This is accepted, and now we have an ill-typed term bound in the global
> context.
> --Randy
