coq-club - Re: [Coq-Club] Questions about two theorems
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Questions about two theorems
  • Date: Mon, 15 Sep 2014 23:41:46 +0400
I proved this in Agda, maybe it would be useful for you:
http://lpaste.net/111082
2014-09-15 21:41 GMT+04:00, Cedric Auger
<sedrikov AT gmail.com>:
> 2014-09-15 17:50 GMT+02:00 John Wiegley
> <johnw AT newartisans.com>:
>> >>>>> Cedric Auger
>> >>>>> writes:
>> > You can then define a injection f which sends any (x:fin (S n)) such
>> > that
>> > (x≠hd) to some (y:fin n).
>> Thanks to you and Daniel, I am now much closer. However, I'm still
>> having
>> difficulty with the above statement: what about the case where hd is not
>> the
>> greatest element of fin (S n)? Then the fact that x <> hd doesn't help
>> me,
>> since hd could be an element which *should* be in y, rather than x. It
>> seems
>> like your proof assumes an ordered set from greatest to last, when the
>> original statement requires no ordering. Daniel did make reference to
>> the
>> fact that having a sorting property could make things easier.
>> John
> In what you wrote, there is a natural ordering. In my initial proof, you
> could omit the notion of order.
> I rewrite the fin type as I do not remember its exact definition.
> Fixpoint fin (n : nat) : Type :=
> match n with
> | O => emptySet
> | S n => option (fin n)
> end.
> The injection I was thinking of was:
> Fixpoint inj (n : nat) : fin (S (S n)) -> fin (S (S n)) -> fin (S n) :=
> match n with
> | S n => fun x y =>
> match x with
> | None => match y with None => @None (fin (S n)) | Some y => y end
> | Some x => match y with None => @None (fin (S (S n)) | Some y => Some
> (inj n x y) end
> | O => fun _ _ => @None (fin O)
> end.
> Lemma inj_spe : forall n (x y z : fin (S (S n))), x<>y -> x<>z -> inj x y =
> inj x z -> y = z.
> Here, there is no notion of order. But you can use the following one if you
> want:
> Fixpoint lt (n : nat) : fin n -> fin n -> Prop :=
> match n with
> | O => fun x _ => match x with end
> | S n => fun x y => match x with None => False | Some x => match y with
> None => True | Some y => lt n x y end
> end.
> .../Sedrikov\...
