- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Questions about two theorems
- Date: Tue, 16 Sep 2014 17:42:47 +0200
2014-09-16 17:21 GMT+02:00 Daniel Schepler <dschepler AT gmail.com>:
On Tue, Sep 16, 2014 at 2:11 AM, Cedric Auger <sedrikov AT gmail.com> wrote:
> Yes, that is clever.
> By the way, I do not know why people use this definition of "fin" which I
> find rather inconvenient.
> Inductive emptySet : Type := .
> Fixpoint fin2 (n : nat) : Type := match n with O => emptySet | S n => option
> (fin2 n) end.
> is a lot more convenient from my point of view.
> Here, we do not have to do all these inversion stuff when inspecting an
> element.
I've often found that inductive versions have nicer extractions to
OCaml than the corresponding Fixpoint to Type or Set definitions whose
extractions require a lot of Obj.magic.
Daniel Schepler
Yes, you are right, I forgot about this.
Still, beware when passing a value of such an extracted type, as the indice is lost in the translation.
I mean, "fin" will be extracted to:
type fin = FinO | FinS of fin
and a function of type "fin 2 -> bool" will be extracted as a "fin -> bool", and thus could be passed "FinS (FinS (FinS (FinS FinO)))" as value although this does not make sense in the Coq world.
When I want to extract code to Ocaml, I often try to provide a "safe" interface, that is one for which all types are identically translated. This "fin" type (and even less the one I defined) would not appear in this interface (unless for functions using a "fin 1", "fin 2", … type which I can normalize as option… types, so translation to Ocaml is the identity).
.../Sedrikov\...
- Re: [Coq-Club] Questions about two theorems, (continued)
- Re: [Coq-Club] Questions about two theorems, Daniel Schepler, 09/15/2014
- Re: [Coq-Club] Questions about two theorems, Cedric Auger, 09/15/2014
- Re: [Coq-Club] Questions about two theorems, John Wiegley, 09/15/2014
- Re: [Coq-Club] Questions about two theorems, Cedric Auger, 09/16/2014
- Re: [Coq-Club] Questions about two theorems, Thorsten Altenkirch, 09/16/2014
- Re: [Coq-Club] Questions about two theorems, flicky frans, 09/16/2014
- Re: [Coq-Club] Questions about two theorems, Daniel Schepler, 09/16/2014
- Re: [Coq-Club] Questions about two theorems, flicky frans, 09/15/2014
