- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Questions about two theorems
- Date: Tue, 16 Sep 2014 13:37:57 +0400
Cedric Auger, I see no difference between these representations:
http://lpaste.net/111113
Are you talking about something Coq-specific? Could you give an example?
2014-09-16 13:11 GMT+04:00, Cedric Auger
<sedrikov AT gmail.com>:
> Yes, that is clever.
> By the way, I do not know why people use this definition of "fin" which I
> find rather inconvenient.
> Inductive emptySet : Type := .
> Fixpoint fin2 (n : nat) : Type := match n with O => emptySet | S n =>
> option (fin2 n) end.
> is a lot more convenient from my point of view.
> Here, we do not have to do all these inversion stuff when inspecting an
> element.
> 2014-09-15 18:06 GMT+02:00 Daniel Schepler
> <dschepler AT gmail.com>:
>> On Mon, Sep 15, 2014 at 8:50 AM, John Wiegley
>> <johnw AT newartisans.com>
>> wrote:
>> > Thanks to you and Daniel, I am now much closer. However, I'm still
>> having
>> > difficulty with the above statement: what about the case where hd is
>> > not
>> the
>> > greatest element of fin (S n)? Then the fact that x <> hd doesn't help
>> me,
>> > since hd could be an element which *should* be in y, rather than x. It
>> seems
>> > like your proof assumes an ordered set from greatest to last, when the
>> > original statement requires no ordering. Daniel did make reference to
>> the
>> > fact that having a sorting property could make things easier.
>> OK, here's a complete solution. As opposed to what Auger suggested,
>> my proof essentially proceeds by cases depending on whether or not
>> FinO is in the list. That makes it easier to define the injection {
>> x:Fin (S n) | x <> FinO } -> Fin n.
>> Require Import List.
>> Require Import Arith.
>> Inductive Fin : nat -> Set :=
>> | FinO : forall {n:nat}, Fin (S n)
>> | FinS : forall {n:nat}, Fin n -> Fin (S n).
>> Definition Fin_0_inv (P : Fin 0 -> Type) :
>> forall x:Fin 0, P x :=
>> fun x =>
>> match x in (Fin z) return
>> (match z return (Fin z -> Type) with
>> | 0 => P
>> | S _ => fun _ => unit
>> end x) with
>> | FinO _ => tt
>> | FinS _ _ => tt
>> end.
>> Definition Fin_Sn_inv {n:nat} (P : Fin (S n) -> Type)
>> (PO : P FinO) (PS : forall y:Fin n, P (FinS y)) :
>> forall x:Fin (S n), P x :=
>> fun x =>
>> match x in (Fin Sn) return
>> (match Sn return (Fin Sn -> Type) with
>> | 0 => fun _ => unit
>> | S n' => fun x => forall (P : Fin (S n') -> Type),
>> P FinO -> (forall y:Fin n', P (FinS y)) ->
>> P x
>> end x) with
>> | FinO _ => fun P PO PS => PO
>> | FinS _ y => fun P PO PS => PS y
>> end P PO PS.
>> Definition FinS_inv {n:nat} (x:Fin (S n)) :
>> option (Fin n) :=
>> Fin_Sn_inv (fun _ => option (Fin n)) None (@Some _) x.
>> Fixpoint map_FinS_inv {n:nat} (l : list (Fin (S n))) :
>> list (Fin n) :=
>> match l with
>> | nil => nil
>> | cons x l' =>
>> let recval := map_FinS_inv l' in
>> match FinS_inv x with
>> | Some y => cons y recval
>> | None => recval
>> end
>> end.
>> Lemma map_FinS_inv_len_noO :
>> forall {n:nat} (l : list (Fin (S n))),
>> ~ In FinO l -> length (map_FinS_inv l) = length l.
>> Proof.
>> induction l; simpl.
>> + reflexivity.
>> + destruct a using Fin_Sn_inv; simpl; intuition.
>> Qed.
>> Lemma map_FinS_inv_len_NoDup :
>> NoDup l -> length l <= S (length (map_FinS_inv l)).
>> Proof.
>> induction 1; simpl.
>> + repeat constructor.
>> + destruct x using Fin_Sn_inv; simpl; intros.
>> - rewrite map_FinS_inv_len_noO; trivial.
>> - auto with arith.
>> Qed.
>> Lemma in_map_FinS_inv : forall {n:nat} (l : list (Fin (S n)))
>> (y : Fin n), In y (map_FinS_inv l) -> In (FinS y) l.
>> Proof.
>> induction l; simpl.
>> + trivial.
>> + destruct a using Fin_Sn_inv; simpl.
>> - auto.
>> - destruct 1.
>> * left; f_equal; trivial.
>> * right; auto.
>> Qed.
>> Lemma map_FinS_inv_NoDup : forall {n:nat} (l : list (Fin (S n))),
>> NoDup l -> NoDup (map_FinS_inv l).
>> Proof.
>> induction 1; simpl.
>> + constructor.
>> + destruct x using Fin_Sn_inv; simpl.
>> - trivial.
>> - constructor; trivial. contradict H. apply in_map_FinS_inv; trivial.
>> Qed.
>> Theorem fin_list : forall {n:nat} (l : list (Fin n)),
>> NoDup l -> length l <= n.
>> Proof.
>> induction n.
>> + destruct l.
>> - trivial.
>> - destruct f using Fin_0_inv.
>> + intros. apply le_trans with (1 := map_FinS_inv_len_NoDup l H).
>> auto using le_n_S, map_FinS_inv_NoDup.
>> Qed.
>> Daniel Schepler
> .../Sedrikov\...
- [Coq-Club] Questions about two theorems, John Wiegley, 09/15/2014
- Re: [Coq-Club] Questions about two theorems, Daniel Schepler, 09/15/2014
- Re: [Coq-Club] Questions about two theorems, Cedric Auger, 09/15/2014
- Re: [Coq-Club] Questions about two theorems, John Wiegley, 09/15/2014
- Re: [Coq-Club] Questions about two theorems, Cedric Auger, 09/16/2014
- Re: [Coq-Club] Questions about two theorems, Thorsten Altenkirch, 09/16/2014
- Re: [Coq-Club] Questions about two theorems, flicky frans, 09/16/2014
- Re: [Coq-Club] Questions about two theorems, Daniel Schepler, 09/16/2014
- Re: [Coq-Club] Questions about two theorems, flicky frans, 09/15/2014
