- From: Abhishek Anand <abhishek.anand.iitg AT gmail.com>
- To: coq-club <coq-club AT inria.fr>
- Subject: [Coq-Club] microcontroller operational semantics with timing?
- Date: Fri, 19 Sep 2014 23:38:47 -0400
Hi,
Is there a formalization of the operational semantics
of a microcontroller (preferably RISC)
such that the formalization includes timing behaviour,
such as how long (e.g. clock cycles) programs take to run?
It would be great if formalization includes the instructions for interacting
with ADCs and digital IO pins.
If not, does someone have suggestions about a cheap
microcontroller that has a simple instruction set
with a simple and well documented timing behaviour?
Thanks,
-- Abhishek
http://www.cs.cornell.edu/~aa755/- [Coq-Club] microcontroller operational semantics with timing?, Abhishek Anand, 09/20/2014
- Re: [Coq-Club] microcontroller operational semantics with timing?, Timothy Carstens, 09/20/2014
- Re: [Coq-Club] microcontroller operational semantics with timing?, David MENTRÉ, 09/20/2014
- Re: [Coq-Club] microcontroller operational semantics with timing?, Dominic Mulligan, 09/20/2014
- Re: [Coq-Club] microcontroller operational semantics with timing?, Brian Campbell, 09/22/2014
- Re: [Coq-Club] microcontroller operational semantics with timing?, Frédéric Blanqui, 09/23/2014
- RE: [Coq-Club] microcontroller operational semantics with timing?, Soegtrop, Michael, 09/22/2014
