- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Function : Cannot define graph(s) when it should?
- Date: Sat, 20 Sep 2014 09:56:12 +0200
Hi Jonathan,
this is clearly a bug. Can you please fill a bug report and, if
possible, assign it to me
(forest AT ensiie.fr).
The bug seems to come from the use of maximal implicit argument on Acc.
For now, you can then remove the brackets on Acc to recover a normal
behavior.
Best regard,
Julien
On Fri, 19 Sep 2014 15:56:55 -0400
Jonathan
<jonikelee AT gmail.com>
wrote:
In the following attempt to use Function to get a functional
induction scheme:
Inductive btree : Set :=
| Leaf : btree
| Node : btree -> nat -> btree -> btree.
Function ascend{Acc : Set}
(f : Acc -> nat -> Acc -> Acc)(i : Acc)
(t : btree) {struct t}
: Acc :=
match t with
| Leaf => i
| Node lc a rc => f (ascend f i lc) a (ascend f i rc)
end.
I get the warning "Cannot define graph(s) for ascend". From the
reference manual, this warning should occur if ascend uses pattern
matching on dependent types, or if the definition is not a
pattern-matching tree with applications only at the end of each
branch.
To me, it looks like ascend is not violating either of those rules.
What am I missing here?
-- Jonathan
- [Coq-Club] Function : Cannot define graph(s) when it should?, Jonathan, 09/19/2014
- Re: [Coq-Club] Function : Cannot define graph(s) when it should?, Rui Baptista, 09/20/2014
- <Possible follow-up(s)>
- Re: [Coq-Club] Function : Cannot define graph(s) when it should?, julien . forest, 09/20/2014
