- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] microcontroller operational semantics with timing?
- Date: Fri, 19 Sep 2014 20:45:33 -0700
It might be hard to find a current microcontroller which would fit thr bill. Modern pipeline design practices don't lead to such tight specifications regarding timing. Contention for functional units, out of order execution, power management, and especially cache, all contribute to variable execution timings for instructions. This would be especially true for small chips with integrated DSP capabilities.
On Sep 19, 2014 8:39 PM, "Abhishek Anand" <abhishek.anand.iitg AT gmail.com> wrote:
Hi,Is there a formalization of the operational semanticsof a microcontroller (preferably RISC)such that the formalization includes timing behaviour,such as how long (e.g. clock cycles) programs take to run?It would be great if formalization includes the instructions for interactingwith ADCs and digital IO pins.If not, does someone have suggestions about a cheapmicrocontroller that has a simple instruction setwith a simple and well documented timing behaviour?Thanks,-- Abhishekhttp://www.cs.cornell.edu/~aa755/
- [Coq-Club] microcontroller operational semantics with timing?, Abhishek Anand, 09/20/2014
- Re: [Coq-Club] microcontroller operational semantics with timing?, Timothy Carstens, 09/20/2014
- Re: [Coq-Club] microcontroller operational semantics with timing?, David MENTRÉ, 09/20/2014
- Re: [Coq-Club] microcontroller operational semantics with timing?, Dominic Mulligan, 09/20/2014
- Re: [Coq-Club] microcontroller operational semantics with timing?, Brian Campbell, 09/22/2014
- Re: [Coq-Club] microcontroller operational semantics with timing?, Frédéric Blanqui, 09/23/2014
- RE: [Coq-Club] microcontroller operational semantics with timing?, Soegtrop, Michael, 09/22/2014
