- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Unusual drinker-like paradox
- Date: Thu, 02 Oct 2014 17:22:49 -0400
On 10/02/2014 01:02 PM, Eddy Westbrook wrote:
Well, but given that it is a choice principle, maybe we can conclude (in
response to Jonathan’s original question) that it is not really constructive…?
-Eddy
Mostly, I was just trying to think of what Coq's logic would allow if its Prop elimination rules were extended to allow Prop elimination anywhere in a Prop-rooted proof subtree instead of just in Prop subgoals themselves.
It is interesting that such an extension would be equivalent to a kind of weak choice axiom. Because I was just thinking in very practical terms - sometimes one finds oneself in a non-Prop subgoal in a Prop-rooted proof subtree and needs to analyze a Prop - and currently the only way to do that is to undo back to some earlier Prop subgoal (perhaps the root of that subtree) and do the analysis there - and such undoing could require restructuring the proof. So, I thought that such an extension wouldn't add anything at all to the logic - but it does. And, it's a weak choice axiom, hence not constructive.
But, I guess that brings out a different kind of theoretical question. Coq's Props already have a different logic (impredicative) from the logic of Types. And, of course, one doesn't have to worry about what Props would extract to, as they don't. Why then keep Prop so constructive?
Certainly, one can always add their favorite choice axiom(s). But, the above Prop-subtree elimination extension, even though it seems to be equivalent to a weak choice axiom, can't be added through use of any such axiom (that would be consistent with the rest of Coq's logic) - at least I can't see how.
-- Jonathan
On Oct 2, 2014, at 9:41 AM, Arnaud Spiwack
<aspiwack AT lix.polytechnique.fr>
wrote:
Well, this principle of choice is equivalent to the dependent version of
Pierre-Marie's above: [forall A B, (forall x:A, inhabited B) -> inhabited
(forall x:A, B)]. I don't think it implies excluded-middle by itself. But it
does if you add in quotient types. The non-dependent version, however, seems
pretty weak.
On 2 October 2014 18:01, Eddy Westbrook
<westbrook AT kestrel.edu>
wrote:
Yes, you are right, thanks!
I got the name TTDA from Werner's paper "Sets in Types, Types in Sets", where
he has a different axiom that he calls a choice principle.
It also looks like AC_fun in Coq.Logic.ChoiceFacts.
So, then, does this version of choice imply excluded middle? I can't find a
proof in the standard library...
Eddy
Sent from my iPhone
On Oct 1, 2014, at 6:12 PM, Jonathan
<jonikelee AT gmail.com>
wrote:
On 10/01/2014 09:01 PM, Eddy Westbrook wrote:That looks like Coq.Logic.ClassicalChoice.choice.
The nondep_AC axiom below is, I think, equivalent to the Type-Theoretic
Description Axiom (TTDA), which is this:
Definition TTDA : Type :=
forall (A B : Type) (P : A -> B -> Prop),
(forall (a : A), exists b, P a b) ->
(exists f, forall (a : A), P a (f a)).
TTDA has some sort of non-constructive content, in that it, with
propositional Excluded Middle, allows you to prove informative Excluded
Middle. I am not what TTDA just by itself allows, however.
-Eddy
On Oct 1, 2014, at 5:29 AM, Pierre-Marie Pédrot
<pierre-marie.pedrot AT inria.fr>
wrote:
On 30/09/2014 22:47, Jonathan wrote:It seems instead equivalent to a weak form of a non-dependent axiom of
Anyone seen it before?
choice, rather than to excluded middle :
Definition nondep_AC := forall A B, (A -> inhabited B) -> inhabited (A
-> B).
Definition escape := forall A, inhabited (inhabited A -> A).
Lemma dir : nondep_AC -> escape.
Proof.
intros ac A; apply ac; trivial.
Qed.
Lemma rev : escape -> nondep_AC.
Proof.
intros esc A B f.
destruct (esc B) as [g].
constructor; auto.
Qed.
PMP
- Re: [Coq-Club] Unusual drinker-like paradox, Robert Dockins, 10/01/2014
- <Possible follow-up(s)>
- Re: [Coq-Club] Unusual drinker-like paradox, Pierre-Marie Pédrot, 10/01/2014
- Re: [Coq-Club] Unusual drinker-like paradox, Arnaud Spiwack, 10/01/2014
- Re: [Coq-Club] Unusual drinker-like paradox, Eddy Westbrook, 10/02/2014
- Re: [Coq-Club] Unusual drinker-like paradox, Jonathan, 10/02/2014
- Re: [Coq-Club] Unusual drinker-like paradox, Arnaud Spiwack, 10/02/2014
- Re: [Coq-Club] Unusual drinker-like paradox, Arnaud Spiwack, 10/07/2014
- Re: [Coq-Club] Unusual drinker-like paradox, Eddy Westbrook, 10/07/2014
- Re: [Coq-Club] Unusual drinker-like paradox, Jonathan, 10/07/2014
