Re: [Coq-Club] Recursive Function identifier "not found in the current environment"
- From: Christoph-Simon Senjak <christoph.senjak AT ifi.lmu.de>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Recursive Function identifier "not found in the current environment"
- Date: Thu, 16 Oct 2014 15:53:01 +0200
Ok. Nevermind. There are pending obligations. I would have expected that these are shown after the definition, just notice that you have to ask for them.
Am 15.10.2014 um 20:57 schrieb Christoph-Simon Senjak:
Hello.
I am using the current trunk (db8e0d7ecaf233ae73705d2f57635a38f8825dad).
My overall project can be found under
https://github.com/dasuxullebt/deflate/, I updated the file
"InflateUnverified.v", I attached here.
When I come to its last line, I get an error "The reference inflate was
not found in the current environment". When I remove everything inside
the "inflate" function, and only leave the (commented) catch-all
pattern, it works.
(Originally I wanted to do recursive extraction, which failed with the
same error.)
Best Regards
- [Coq-Club] Recursive Function identifier "not found in the current environment", Christoph-Simon Senjak, 10/15/2014
- Re: [Coq-Club] Recursive Function identifier "not found in the current environment", Christoph-Simon Senjak, 10/16/2014
- <Possible follow-up(s)>
- Re: [Coq-Club] Recursive Function identifier "not found in the current environment", julien . forest, 10/16/2014
- Re: [Coq-Club] Recursive Function identifier "not found in the current environment", Pierre Courtieu, 10/16/2014
- Re: [Coq-Club] Recursive Function identifier "not found in the current environment", Christoph-Simon Senjak, 10/18/2014
- Re: [Coq-Club] Recursive Function identifier "not found in the current environment", julien . forest, 10/18/2014
