Re: [Coq-Club] Recursive Function identifier "not found in the current environment"
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Recursive Function identifier "not found in the current environment"
- Date: Thu, 16 Oct 2014 18:23:53 +0200
On Thu, 16 Oct 2014 17:56:21 +0200
Pierre Courtieu
<pierre.courtieu AT gmail.com>
wrote:
buh je le vois pas le fix, il est caché?Dear Pierre,
P.
2014-10-16 17:46 GMT+02:00
<julien.forest AT ensiie.fr>:
> On Thu, 16 Oct 2014 15:53:01 +0200
> Christoph-Simon Senjak
<christoph.senjak AT ifi.lmu.de>
wrote:
>> Ok. Nevermind. There are pending obligations. I would have expected
>> that these are shown after the definition, just notice that you
>> have to ask for them.
>> Am 15.10.2014 um 20:57 schrieb Christoph-Simon Senjak:
>> > Hello.
>> > I am using the current trunk
>> > (db8e0d7ecaf233ae73705d2f57635a38f8825dad). My overall project
>> > can be found under https://github.com/dasuxullebt/deflate/, I
>> > updated the file "InflateUnverified.v", I attached here.
>> > When I come to its last line, I get an error "The reference
>> > inflate was not found in the current environment". When I remove
>> > everything inside the "inflate" function, and only leave the
>> > (commented) catch-all pattern, it works.
>> > (Originally I wanted to do recursive extraction, which failed
>> > with the same error.)
>> > Best Regards
> Hi Simon,
> your "inflate" function contains a "fix" construction which is not
> allowed by Function (See Section 2.3 of reference manual).
> Btw, I cannot reproduce the pending proof obligations. Can you tell
> me which version you are using ?
> Best regards,
> Julien Forest
the fix construct is on line 194.
Regards,
Julien
- [Coq-Club] Recursive Function identifier "not found in the current environment", Christoph-Simon Senjak, 10/15/2014
- Re: [Coq-Club] Recursive Function identifier "not found in the current environment", Christoph-Simon Senjak, 10/16/2014
- <Possible follow-up(s)>
- Re: [Coq-Club] Recursive Function identifier "not found in the current environment", julien . forest, 10/16/2014
- Re: [Coq-Club] Recursive Function identifier "not found in the current environment", Pierre Courtieu, 10/16/2014
- Re: [Coq-Club] Recursive Function identifier "not found in the current environment", Christoph-Simon Senjak, 10/18/2014
- Re: [Coq-Club] Recursive Function identifier "not found in the current environment", julien . forest, 10/18/2014
