coq-club - Re: [Coq-Club] Recursive Function identifier "not found in the current environment"
  • To: Christoph-Simon Senjak <christoph.senjak AT ifi.lmu.de>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Recursive Function identifier "not found in the current environment"
  • Date: Thu, 16 Oct 2014 17:46:47 +0200
On Thu, 16 Oct 2014 15:53:01 +0200
wrote:
Ok. Nevermind. There are pending obligations. I would have expected
that these are shown after the definition, just notice that you have
to ask for them.
Am 15.10.2014 um 20:57 schrieb Christoph-Simon Senjak:
> Hello.
> I am using the current trunk
> (db8e0d7ecaf233ae73705d2f57635a38f8825dad). My overall project can
> be found under https://github.com/dasuxullebt/deflate/, I updated
> the file "InflateUnverified.v", I attached here.
> When I come to its last line, I get an error "The reference inflate
> was not found in the current environment". When I remove everything
> inside the "inflate" function, and only leave the (commented)
> catch-all pattern, it works.
> (Originally I wanted to do recursive extraction, which failed with
> the same error.)
> Best Regards
Hi Simon,
your "inflate" function contains a "fix" construction which is not
allowed by Function (See Section 2.3 of reference manual).
Btw, I cannot reproduce the pending proof obligations. Can you tell me
which version you are using ?
Best regards,
Julien Forest
